Suspension & Brakes Theory, alignment, spring rates....
Tein superstreet springs?
Old Aug 26, 2009 | 08:03 AM
EJ1B18c's Avatar
Default Tein superstreet springs?
Hi i have a quick question. I have a set of Tein superstreet coilovers on my ej1. looking for stiffer springs at the moment i have approx 380lb/in on the front and 180lb/in on the rear. I want to know if i can fit say eibach or koni springs to my Tein Dampers? Or would it be easier to buy koni dampers and buy my springs of choice.
Old Aug 26, 2009 | 12:08 PM
racebum's Avatar
Default Re: Tein superstreet springs?
measure the ID of your springs & let us know what the number is
Old Aug 27, 2009 | 01:55 AM
EJ1B18c's Avatar
ID is 70mm.
Old Aug 27, 2009 | 06:43 AM
EJ1B18c's Avatar
Scratch that i called my eibach supplier they provide springs in 685lb/in MAX with a 70mm ID. And 1200lb/in and 900lb/in with a 62.5mm ID. So i gotta take my coilovers off and see if a 62.5mm ID will fit.
If not do you know of any company that make springs with a 70mm ID 200mm long and rates of 1200lb/in and 900lb/in.Thanks
Old Aug 27, 2009 | 08:50 AM
Mashimaro's Avatar
even if the springs fit, the Tein damper may not be able to handle too much of a higher rate...just a possibility for you to consider.
Old Aug 27, 2009 | 09:33 AM
Egezzy's Avatar
Spongebrad Squarepants
what he said.
Old Aug 27, 2009 | 09:37 AM
EJ1B18c's Avatar
I was thinking that alright. I wonder if there is a way of knowing if it will be able to hack it.
Old Aug 27, 2009 | 11:34 AM
racebum's Avatar
are you driving on full blown slicks? i can't imagine why you would need rates that high on even R compounds unless you are one of those guys who actually enjoys a tight car. personally i'm always faster slightly loose. the 500 range is as high as i would ever go on non R compound tires.
Old Aug 27, 2009 | 11:52 PM
EJ1B18c's Avatar
i run on Toyo R888. Anyways regardless. It will work out cheaper if i sell what i have now, i can sell my current set up for €650. And buy new koni's and springs again.
mugensport9
16
Aug 5, 2003 01:16 PM
redluder
Apr 10, 2003 10:12 AM
LOwrestling2001
Jul 28, 2002 09:52 PM
juniordc2
Apr 15, 2002 06:04 PM
