WTT-WTS 92 eg hatch drag/street car 11sec clean
car only has 14 passes in amarillo tx car runs consistent 11.9 best 11.8@119 1.82 60ft. the car drives great. has 20 psi oil pressure at 500 rpm around 60 at 3000 rpm. uses no oil or antifreeze! i will get some interior and body pics up sat. car has a clean body no dents or rust and is painted flat black paint. NOT PRIMER lol im getting ride of it cause im trying to fix my crx project i dont need to drag cars. clean title. I AM WILLING TO TRADE FOR ANYTHING I WOULD LIKE TO GET AROUND 5000 SHOOT ME SOME OFFERS. ANY QUESTIONS CALL OR TXT1-575-749-3103 ROCKY
motor
b16a stock bottom end with block gaurd
b16 head ported bye me
supertech bronze guides
blox coated valves
5 angle valve job
arp head studs
cometic head gasket
b18c cams
rick stiles cam gears
acl bearings
type r oil pump
type r crank pulley
trans
b16 lsd trans
stage 5 competition clutch 4 puck solid hub
fidanza aluminum flywheel
tci 500hp axles
induction
victor x manifold
70mm bdl throttle body
aem fuel rail
1000cc precisions
earls fuel filter
earls gauge
ebay bov
ebay 50mm wastgate
obx top mount manifold
garrett 60-1 t4 63 ar turbine turbo
ebay intercooler
costom piping all t bolt clamps
aluminum radiator
car
tokico illumina with drag springs rear
tokico blue front
rear nuespeed strut bar
sunpro pro tach
sunpro oil pressure gauge
autometer big *** boost gauge
dual bend skunk 2 shifter
omni power quick clutch
clean tan gsr seats
electronics
hondata s300
jdm ctr gauge cluster
stock dist
ngk wires
gm 3 bar map
video link below
http://videos.streetfire.net/video/c...1-9bd40161faca
motor
blox coated valves
5 angle valve job
arp head studs
cometic head gasket
b18c cams
acl bearings
type r oil pump
type r crank pulley
trans
b16 lsd trans
tci 500hp axles
induction
victor x manifold
aem fuel rail
1000cc precisions
earls fuel filter
earls gauge
ebay bov
ebay 50mm wastgate
ebay intercooler
aluminum radiator
car
tokico blue front
sunpro pro tach
clean tan gsr seats
electronics
hondata s300
stock dist
ngk wires
gm 3 bar map
video link below
jdmrobby
Feb 15, 2013 07:25 AM
cloviskilla
Jun 29, 2010 09:15 PM
cloviskilla
Texas -OK -LA (Sales)
16
Nov 9, 2009 12:29 AM
