Check out my rotors... question about them
Old Aug 25, 2009 | 06:20 PM
jdmwannabee's Avatar
Default Check out my rotors... question about them
i ordered these off of ebay as oem replacements. $52.00 shipped, i got them today and i was kind of disappointed. the casting on where the hub would go looks rough as hell. should i be ok? should i bother to smooth out that area?
Old Aug 25, 2009 | 06:27 PM
tamadrummer1120's Avatar
Default Re: Check out my rotors... question about them
If those castings look like that, I would be worried about them being warped then. Scary thoughts.
Old Aug 25, 2009 | 07:10 PM
phootbag's Avatar
Only one way to find out...
Old Aug 26, 2009 | 04:49 AM
rotor doesn't appear to be warped on any surfaces
bump for more opinions.
Old Aug 26, 2009 | 05:22 AM
TouringAccord's Avatar
H-T Order of Merit
it's a casting, it's going to be rough.
I don't see how anything will be affect. Those are there for the bearing flange to pass through. The face where the hub mounts looks fine.
Old Aug 26, 2009 | 06:53 AM
Conflicted's Avatar
I shopped for a set of rotors on ebay but everything I read about them was negative for the most part as far as their quality, the fact they are thinner than most other mainstream brands etc...
I ended up buying all 4 rotors and sets of pads for 280 from TAS.
Old Aug 26, 2009 | 07:05 AM
Targa250R's Avatar
be professional
Unfortunately, it's pretty common to see rough casting surfaces like that on extremely cheap Chinese-sourced rotors. Those rough edges aren't going to hurt anything, but the rotor may have other issues. All you can do is try them out.
Old Aug 26, 2009 | 07:48 AM
wildstyle554's Avatar
I suppose theyre ok but i wouldnt take any chances with something like my brakes.
Old Aug 26, 2009 | 08:45 AM
I expected the edges to be rough, but they look a bit too rough...
yeah i saw the TAS package wanted it but couldn't afford it at the moment, so i had to go the cheap route. they feel like solid pieces though.
the rotors don't appear to be warped or anything, but as said before i'll try them out.
thanks for the replies guys.
Old Aug 29, 2009 | 04:04 PM
Conflicted's Avatar
Hey, any update on how these are working out for you now that they're on the car?
Old Sep 1, 2009 | 08:54 AM
scrappinfacecb7's Avatar
lol I got brand new in the box rotors for the front stock OEM replacement. DOES NOT LOOK LIKE YOURS lol there fresh
Old Sep 1, 2009 | 09:04 AM
Sales@Bisimoto.com's Avatar
I also would like an update on how these worked?
Old Sep 1, 2009 | 09:20 AM
as mentioned before the castings had no impact on installation, the hub sits nice and flush on the rotor everything went together well. everything fit together well. the only complaint i have is that the coating that's supposed to prevent rust was quite thick and even after several coats of brakleen there was still some on there as i was braking in the pads. all in all, i think these ebay rotors will be sufficient for my car's purpose.
the whole taking apart of the hub over rotor assembly was a pain in the dick. why would honda do this to us?
Old Sep 1, 2009 | 10:12 AM
nicolaselias's Avatar
Loved
Community Favorite
sad to say but in the end you generally gt what you pay for..
I ordered a pair of brembo sport slotted rotors this summer and I was stunned at the finish and the craftsmanship.. every surface was perfectly smoothed and machined..
it pays to look around sometimes, if you manage to catch something on sale you can get some good deals on well respected brands
for brakes I usually browse the selection on tirerack.com and buybrakes.com then buy it whereever is cheapest (including ebay)
Old Sep 1, 2009 | 10:31 AM
djkurious's Avatar
I have a set of duralast rotors on my accord and tahoe with the duralast gold pads. Works good for me and Lifetime warranty.
Old Sep 1, 2009 | 11:59 AM
Targa250R's Avatar
be professional
I've been dealing in Brembo rotors for several years now, and I'm rather unimpressed with the rotors that they've been shipping out for the last several months.
I was told that Brembo recently started seb-letting their rotor manufacturing to other companies around the globe, rather than fabbing them all in-house. Based on the number of rotor warranty returns I've had as of late, I think the quality has suffered.
It's hard to find quality automotive replacement parts these days.
Old Sep 1, 2009 | 06:04 PM
Loved
Community Favorite
Targa, I'm actually surprised to hear that because my Sport slotted's were manufactured in Italy and the quality seemed second to none...
Of course, it is possible that this was pre- sub--letting?
Have you heard of subletting on the sport line of rotors as well or just the "blanks"?
Old Sep 3, 2009 | 03:21 PM
Conflicted's Avatar
For $280 I did the 4 rotor and brake pad set from TASauto.
"90-97 4cyl FT & RR CROSS-DRILLED BRAKE PACKAGE (NISSIN & AKEBONO)
Kit includes front and rear cross-drilled rotors, Semi-metallic front brake pads and Carbomet rear pads. Package gives less brake fade and greater stopping power. Carbomet brake pads are made from a semi-metallic, carbon fiber composite. Carbon fiber is more resistant to heat so you can expect less brake fade under hard braking conditions, increased stopping power and low dust levels. Bolt-on, no modifications needed."
They are OEM plus for both the rotors and the pads which is a plus and they'll give you more performance and stopping power apparently.
Old May 14, 2010 | 01:31 AM
skirtblower's Avatar
Old May 14, 2010 | 01:35 AM
diy how to replace rear rotor and hub on a 1994 honda accord ex 4dr
Old May 14, 2010 | 01:37 AM
Old May 14, 2010 | 03:23 AM
TheMuffinMan's Avatar
He knows where you live!
Really was that necessary?
How about you read the Accord FAQ, don't make 3 pointless posts in a year old thread that has nothing to do with your question.
There is a tutorial in the FAQ, in fact it's the first one listed.
1994PreludeSi
Oct 19, 2007 10:51 PM
zirac50
Apr 16, 2007 05:41 PM
Han Solo
11
Nov 9, 2006 12:03 AM
90AcuraIntegra04
Nov 8, 2005 02:42 PM
ZensokuEK
13
Oct 25, 2003 01:22 PM
