Guages not working, door locks? More questions.. help me out.LOTS OF PROBS
Aight, this is all on a 91 HF CRX.
-Guage Cluster does not seem to be working, when i step on the gas when im in neutral the rev limiter does not move, and also when im going the speedometer dont seem to be working.
- Is the drivers door supposed to be able to close when the door is locked and you try to shut it?
I also have some other weird *** probs. When i turn the car on, then off, it makes both door locks go to open? This may have to do with the viper alarm, cause the alarm dont work right and wont make the doors open all the way, like it wont push the locks far enough. Please someone help me out here. Thank you.
The door doesn't lock because it's a feature to avoid getting your keys locked in the car.... But if you want to, lock the door and hold the handle up as you lock it and it will lock....
Well i found out more weird stuff. My windsheild wipers are slow.. also when i put the cars parking lights on the dash lights will be ok, but then i put the high beams on and they get dim, and the horn sounds less.. could this be because of my battery? Alternator? Thank you.
danmej1
Audio / Security / Video
Mar 20, 2010 11:17 AM
GroundZer0
Aug 27, 2002 10:01 AM
