Axle Help
Old Aug 25, 2009 | 05:51 PM
TheCivicMafia's Avatar
Default Axle Help
Okay, im doing a F/H Swap into my civic ( f22 but should be same as h series too )
Anyone know where to get some good 300+Hp Axels for the 93 Body and f motor?
Ive looked around and cant find any that seem "good" Any help would be appriciated even the name of the conversion part would be helpful
Old Aug 25, 2009 | 05:57 PM
SlickEJ8's Avatar
Default Re: Axle Help
i know napa has some that was rated at 500hp i got some for my integra. check there.
Old Aug 27, 2009 | 02:01 PM
Yeah, I just didnt know what to call them, Because a prelude shaft is longer than the civic shaft and ofc is different. So i kinda needed to know the name or something because its a f22 prelude motor in a eg coupe shell
Old Aug 28, 2009 | 06:14 PM
No one else?
Old Aug 28, 2009 | 06:24 PM
Anon51's Avatar
look up driveshaft shop and ask them to make a set for you or maybe hasport has them. hybrid axles aren't cheap tho since there's lots of mix and matching
Old Aug 28, 2009 | 06:26 PM
I dont want cheap ones, i dont know why i put 300+ anyways my build will be 400-450 So ill need something in that range
I dont want custom axels, Welds tend to create weak points when pushing alot of power and boost Ive found one or two but none 450+ only a 350 hp one which may have to work.
Old Aug 28, 2009 | 06:36 PM
Anon51's Avatar
no welds. they cuz and remachine the splines. they know how to make axles
Old Aug 28, 2009 | 07:25 PM
trustdestruction's Avatar
Quick question... how much did you pay for them?
OP: Get some from the driveshaft shop
Old Aug 30, 2009 | 01:47 PM
jdm_obsession88's Avatar
raxles.com or hasport. I have hasport in my h22a eg6.
Old Sep 1, 2009 | 12:54 PM
But will those hasport axles handle 400+ HP on a daily basis?
Cdubz628
Apr 15, 2014 02:09 PM
iv4hcx3l4
32
Feb 10, 2008 07:06 PM
