obd0 to od1 on my da
Old Aug 25, 2009 | 05:26 PM
e12ikktos's Avatar
Default obd0 to od1 on my da
i would like to convert my 90 da to an obd1 because i plan on doing a b20vtec and the only way to run my vtec is threw the ecu since it is chipped for no rev
would i need a gsr harness since from what i read a 92-93 gsr is obd1
or can i still use my harness jus with a few changes
Old Aug 25, 2009 | 09:28 PM
bmcp.'s Avatar
Default Re: obd0 to od1 on my da
i used my obd0 harness with my obd1 conversion when i swapped my b17 in my da. only a few things are different.
Old Aug 25, 2009 | 09:56 PM
jhammond_82's Avatar
Reject Papi
http://www.g2ic.com/forums/showthread.php?t=86612
Old Aug 26, 2009 | 02:21 PM
e12ikktos's Avatar
thanks
heps out
ill jus keep reading over and over
Old Aug 26, 2009 | 03:00 PM
bks84's Avatar
Loved
I have an engine harness built by hasport that has all the wiring for VTEC added... also has the obd0 to obd1 jumper harness and sub harness. its set up to use obd1 injectors and gets rid of the resistor box. its a plug and play thing. takes all the hassle out of converting. $250
LakeSquad_ed3
Oct 17, 2014 10:40 AM
t-town_ep
Nov 19, 2012 12:54 AM
lejeaune
Apr 21, 2010 09:31 AM
bobbyisking
Jul 7, 2008 09:22 AM
DA6righthand
Oct 4, 2005 10:25 PM
