REAR BRAKE IS STICKING
Old Aug 25, 2009 | 03:32 PM
KillrB16's Avatar
Default REAR BRAKE IS STICKING
The pass. side rear brake on my '99 Si seems to keep getting stuck. I had/have aftermarket slotted rotors, and the reason I say had is that on that particular wheel they sent me the wrong side rotor (slots were going the wrong way). After a few more mix ups with the company I got them thru, I decided to just put the one I had got on and be done with it. Well I first noticed that the rear pass. rim was aways the dirtiest and after only a year or so of driving I have worn the pads (ceramic) out. First I switched back to my original stock rotor. No difference the rim still got way dustier than the others. Next I replaced the pads knowing that something must be wrong. I've driven the car for about two weeks now and it is still dragging.
I am thinking that I need a new caliper, but that is mostly a guess. I'm not sure how these brakes adjust themselves exactly. I know with drum brakes they adj. when you back up and stop, but do disc rear brakes do the same? I park on an inclined driveway at night so I use th E-brake everytime I park there. Could that be part of the problem? The other side rear seems to be working just fine, so I don't know if that makes a difference.
THANKS
Old Aug 26, 2009 | 05:58 PM
KillrB16's Avatar
Default Re: REAR BRAKE IS STICKING
Sticky Brakes....
The Notorious Frosty
Nov 28, 2010 07:16 AM
KyleVA
Nov 24, 2009 09:39 AM
LSVTEC 91 Civic
Honda Fit
37
Nov 15, 2007 05:52 AM
gsr1289
Aug 17, 2006 04:12 PM
GSRnold
Aug 22, 2004 04:29 PM
