Painting my steel wheel - tape
Old Aug 25, 2009 | 02:43 PM
GoLowDrew's Avatar
Old Member
25 Year Member
Icon6 Painting my steel wheel - tape
I need to paint a set of OE black steel wheels black. Why? Just touching up to prevent rust. OE paint job is starting to fade and I "can see metal."
Tires are on the wheel. Not worth the expense to remove them. Plus may replace tires in a year. So no need to be perfect. Now that we got that out of the way.
I got some garbage bags and need some tape.
What kind of tape do you recommend to tape up the wheel? Or should I say rubber?
He used blue tape.
What is it, and what do you recommend?
Old Aug 25, 2009 | 02:56 PM
madblkscientist's Avatar
Default Re: Painting my steel wheel - tape
use painters tape because it wont leave a residue, its easy to remove, not harsh n sticky,and if u take ur time u can curve the tape to the rim.
try to get thiner tape than me i had a crap load of that left over try the 1 inch then put ur garbage bags or paper half way over the tape then retape bag on so u have it covered good
r the rims bare?
Old Aug 25, 2009 | 03:13 PM
g2_DB's Avatar
try using 3x5 index cards and putting it between the rim and rubber
Old Aug 25, 2009 | 03:23 PM
that could work also
Old Aug 25, 2009 | 03:44 PM
chawski's Avatar
Thats what ive always done. just overlap the cards by about 1/3 to make sure everything is covered, and then a small strip of tape bw each card just in case there is a gust of wind or something. you really cant F it up. worst case scenario is you just re-do it
Old Aug 25, 2009 | 05:30 PM
what do u have on hand blue tape is cheap
Old Aug 25, 2009 | 11:10 PM
fav6052's Avatar
Old Aug 28, 2009 | 10:07 AM
hilaaryjohn72's Avatar
thats a very good idea.if you do this it can save your vehicle with the rust??
alaaaaanna
Jun 3, 2013 04:46 AM
foxdecoy
Paint and Body
Dec 5, 2008 09:56 PM
eg6sir88
Nov 20, 2007 11:53 AM
DA9_DAD
11
Oct 5, 2005 03:41 PM
stoopid_monkey
Mar 2, 2005 11:24 AM
