94 ls-v roaming idle
Old Aug 25, 2009 | 02:28 PM
4g4dcruisin's Avatar
Default 94 ls-v roaming idle
first of all i HAVE SEARCHED but couldnt find anything.
i've just replaced my head gasket, fired up the car and it started first try. but the weird thing is that it would be at like 1300rpm as soon as it starts, then gradually settles at about 1000rpm. after a few minutes, it will drop to about 800rpm then to like 300rpm. once it drops off to 300rpm, it fluctuates from there to like 800rpm.
i KNOW i do not have a vacuum leak, no CEL's, IACV is perfectly fine since it was idling at about 1100rpm BEFORE i did the head gasket.
the only thing i can think of is maybe the dizzy? as of right now i have it tilted ALL the way towards the firewall.
Old Aug 30, 2009 | 05:03 AM
misha's Avatar
Default Re: 94 ls-v roaming idle
do you have bubbles in your coolant?
let the car cool off, open the rad cap, start the car, add a bit more coolant till you have a ncie flow in the rad hole. When the car warms up and the coolant will starting to rise close the cap.
You should get rid of the bubbles, but it might put to much coolant in there as well. It will ealk out from your cap, smell a bit but then you shoudl be just fine.
If thats your problem. But it seems to me when the bubble flows through IACV its making it go up and down sorta thing.
GL
Old Aug 30, 2009 | 08:17 AM
97integraduals's Avatar
Sounds like air in the system...or even just a dirty IACV but yeah, Id just try the coolant bleed first.
Old Aug 30, 2009 | 09:38 AM
im not familiar with the "coolant bleed".
Old Aug 30, 2009 | 10:11 AM
edgar97's Avatar
I had a problem similar but my problem was iacv.
Old Aug 30, 2009 | 10:17 AM
92civic_hatch's Avatar
he said his iacv was good. good luck with the diagnosis. i agree with the other posters. theres a write up on here on the procedure
Old Aug 30, 2009 | 12:04 PM
lsturbo*'s Avatar
MAP sensor would also do this. Not sure how it would have changed, and it should throw a CEL if something was bad, but its worth checking
Old Aug 30, 2009 | 12:46 PM
i SOMETIMES have a CEL, it has come on twice since i've done the head gasket. both times it comes on when im just driving normally, then i'll turn off the car, turn it on, and no more CEL.
so yea im confused.
Old Sep 1, 2009 | 11:05 AM
hey i finally put up a video of my problem...notice how long i have the key turned to start up the car, normally i'de give it some gas to start it up but i wanted to show what it does with NO acceleration at start up.
http://s280.photobucket.com/albums/k...t=100_1768.flv
fgraciano1980
Jun 24, 2010 04:13 AM
lil98civi
Sep 7, 2009 03:57 PM
central_driver
10
Mar 16, 2009 03:48 PM
blue89hatch
Aug 13, 2008 05:09 AM
BB6Paul
Oct 5, 2006 10:43 PM
