just a question about my caliper piston (pic inside)
Old Aug 25, 2009 | 01:52 PM
4DALOOKS92's Avatar
Icon2 just a question about my caliper piston (pic inside)
I was changing the rear brake pads on my 92 hatch, I remove the caliper and notice that the caliper piston have rust on it. the rubber that keep the piston clean and lubricated had ripped and came off. i tried pushing the piston with my hand and it didnt move. so based on the pics my question is, can I be able to rebuilt the calipers or buy the whole thing. thank you for your help.
Old Aug 25, 2009 | 01:56 PM
Gunmetal_B20_Hatch's Avatar
Default Re: just a question about my caliper piston (pic inside)
You have to turn the piston while applying pressure to get it to go down.
There is a special tool to make the process alot easier.
But if I were you, I would go ahead and buy a new caliper if the dust seal ripped. Or rebuild it if you are confident enough.
Old Aug 25, 2009 | 02:04 PM
roadsqueegy95's Avatar
ya like gunmetal said, that style piston turns in, not pushes like the front. but i would replace it anyway or rebuild it, or u risk having problems later on down the road
Old Aug 25, 2009 | 05:32 PM
4DALOOKS92's Avatar
thank you for the help, I turned the pistons and it worked. I had to take it out and clean the rust from it though. maybe ill replace the calipers
next time I change the pads
Old Aug 25, 2009 | 06:13 PM
ya i was thinking at the very least id clean up the rust on them the best i could.
colinfindlay
Suspension & Brakes
Jan 29, 2013 11:15 AM
kidcool1977
Nov 30, 2008 05:42 AM
96lewd
Oct 22, 2004 04:20 PM
SKDRCR
Jan 18, 2004 05:18 PM
