How to check radio ground?
Old Aug 25, 2009 | 01:18 PM
1cleanem1's Avatar
Default How to check radio ground?
So I have this whistling sound coming from the front of my car and the mechanic said to check the ground for my radio. I am a complete noob when it comes to wiring and such and was wondering how to check this? I have an 00 si with alpine HU, alpine speakers, and kenwood amp. Thanks
Old Aug 25, 2009 | 04:53 PM
twentyhurtz's Avatar
Default Re: How to check radio ground?
probably that kenwood amp has a bad ground if its on your highs
usually factory radio grounds are good and tested, the whistling sound is engine whine playing through your speakers i am assuming.
Old Aug 25, 2009 | 05:29 PM
1cleanem1's Avatar
yea i think its the amp too, the sound seems to be coming from the rear.. should i just disconnect it for the time being?
Old Aug 25, 2009 | 06:35 PM
audioroach's Avatar
ummm first check the amps gain control....it may be up too high as to
cause it to allow alternator whine to be heard(above the cars normal noise floor)
turn it down and see if that corrects the issue.
Old Aug 25, 2009 | 06:46 PM
jason0123's Avatar
could be a bad ground in the amp which can also burn up the ground in the head unit also through the rca's. you can also try taking a piece of wire from the ground terminal to the rca input of the amp (ground side) and see if the noise goes away. Then tou will know it is the amp.
Old Aug 26, 2009 | 06:16 AM
1cleanem1's Avatar
lol you guys are speaking jibberish to me but ill try my best.. Thanks for the help
Old Aug 26, 2009 | 06:41 AM
1cleanem1's Avatar
fixed it fellas, thanks
screech527
Audio / Security / Video
Jan 21, 2012 06:52 PM
zsudz922
10
Aug 1, 2007 04:20 PM
laocivic
12
Jul 8, 2007 08:47 AM
dirtycolombian
May 6, 2007 03:23 PM
Devo94ac
Nov 8, 2005 12:15 PM
