dizzy question
Old Aug 25, 2009 | 12:47 PM
speed_demon018's Avatar
Default dizzy question
will a d15 non vtec dizzy work on a d16z6?
Old Aug 25, 2009 | 12:48 PM
THC07's Avatar
Default Re: dizzy question
No!
Old Aug 25, 2009 | 12:49 PM
ok calm down just making sure lol
Old Aug 26, 2009 | 09:21 PM
also another question. ok so my car is cutting our really bad now and is running rich, it cuts out before 2500 rpm and then it clears up after. it sometimes acts like it wants to die even on the high way, i am trying to figure out what the problem is i have replaced the coil, control module, wires, plugs, fuel filter, injectors and it has good fuel pressure
Old Aug 27, 2009 | 10:46 AM
THC07's Avatar
I was calm!
Still am.
Do you have any check engien lights?
Need more info, car/ecu/ have you done anything prior?
How is it cutting out? jerks? missfire? can you tell if its fuel or spark?
Old Aug 27, 2009 | 11:34 AM
the car is a 94 civic ex d16z6, ecu virgin p28, it comes up with a CEL but not all the time its a code 43 but when i am leaving in first gear it wants to die and it falls on its face
Old Aug 28, 2009 | 08:20 AM
THC07's Avatar
43 Fuel supply system
check fuel pressure again. test fuel pump, put a light on ech injector and make sure ech injector is working
hondagirl86
10
May 12, 2014 02:35 PM
Vitamin G
10
Aug 24, 2012 01:20 PM
Vinny97lude
Apr 16, 2004 06:02 AM
93slmdcvcsi
17
Nov 1, 2003 09:46 AM
