whats the result of mixing up the white wires on a dpfi to mpfi???
Old Aug 25, 2009 | 11:29 AM
crxnonvtec's Avatar
Default whats the result of mixing up the white wires on a dpfi to mpfi???
I heard the white wires getting swapped would make the car not run obviously but what are the more specific symptoms??? some people say it thinks the car is running at redline does that shut down the fuel completely?
Old Aug 25, 2009 | 12:42 PM
D16SiHatch's Avatar
Default Re: whats the result of mixing up the white wires on a dpfi to mpfi???
i believe if that happens it will make the car not run, obviously, and you'll throw an igniter output signal code. when the throttle position sensor outer wires are not switched is what makes the car think it's at redline when you're at the opposite.
Old Aug 25, 2009 | 12:52 PM
rustbucketrex's Avatar
If your talking about the white wires at the distributor, your timing will be retarded but you will not get a code from it.
Old Aug 25, 2009 | 01:05 PM
dephtone's Avatar
The car won't even start, the large white wire goes to the Coil for the Ignition Output signal, and the other wire is for Cylinder Position Sensor.
Old Aug 25, 2009 | 01:16 PM
oldschoollove's Avatar
The car won't even start i did that the frist time lol
Old Aug 25, 2009 | 01:19 PM
crxnonvtec's Avatar
just trying to figure out a fuel gremlin the injectors fire once and thats it.....and its not the main relay TDC sensor fuel pump filter injectors or fpr
crxguy406
May 5, 2013 02:56 AM
louevilhatch
Jun 28, 2007 08:45 AM
e jay one
Sep 9, 2006 11:51 AM
B16Civic93
Mar 27, 2005 09:04 AM
