A sneak peak...
Old Aug 25, 2009 | 11:11 AM
BABY NSX's Avatar
Icon6 A sneak peak...
Well after a couple rough years... it looks like my engine build is nearing completion. Less the TB here is what's going on the car tonight:
YES, that's the 3" cat back system and I'll let you guys start telling me that its TOO big
The throttle body is waiting for a new intake manifold (I'm looking for a skunk2 pro series at the moment).
Cheers,
Doug
Old Aug 25, 2009 | 11:16 AM
BABY NSX's Avatar
Default Re: A sneak peak...
oh... this is what the engine put down with a Spoon header and Mugen twin loop:
Other notibles are:
1.8L B18C5
Skunk2 Pro1 cams
11.8CR
Mugen intake
stock ITR intake manifold
+1mm intake valves
as well as all the other suporting mods...
Old Aug 25, 2009 | 12:52 PM
092eg6's Avatar
nice green grass u got there
Old Aug 25, 2009 | 02:14 PM
MrBillyX's Avatar
3"
How big is the motor?
Old Aug 25, 2009 | 06:51 PM
BABY NSX's Avatar
Originally Posted by MrBillyX
3"
1.8L (see my post above)
So I installed the header/exhaust tonight. I'm missing my catalytic converter right now but a short drive tomorrow morning the a nearby custom exhaust shop will take care of that... Ran the car for a minute with the header open... Man I love that sound... reminded me of my times at Mosport.
Small problem with the install... aparently the Skunk2 header doesn't like the TypeR transmission brace and I had to remove it entirely for now just to get the header on. I was disapointed of course as my options now are to find a GSR brace or grind mine down and likely the bolt heads to make the old one fit.
Does anyone have a spare GSR style tranny brace they can send my way?
here are a couple comparison shots:
Skunk2 vs Spoon header:
Mugen TL piping vs Skunk2 piping:
Old Aug 25, 2009 | 07:31 PM
crazydominicanman's Avatar
Skunk2 header is pretty, you going skunk2 crazy lel
Old Aug 25, 2009 | 08:04 PM
ek9poormanr's Avatar
SKUNK2 all the way!
Old Aug 25, 2009 | 11:05 PM
AM_H2B's Avatar
Salesman here.
Old Aug 25, 2009 | 11:27 PM
stumpyf4's Avatar
Had a 70mm Skunk2 with a Tri-y and test pipe, was loud as hell!! My neighbors didn't appreciate my late night drives. I doubt the 76mm will be too big, if you're
not running a cat the collector will be the bottle neck.
Are you gonna retune? I'd be interested to see what this would pull on Tony's dynapack. I pulled 200whp, 130ftlb. GSR with ITR piston, street P&P, Pro1's, tri-y, 70mm exhaust.
Old Aug 26, 2009 | 04:30 AM
BABY NSX's Avatar
Originally Posted by AM_H2B
Salesman here.
Not sure I understand... I definitely don't work for Skunk2 nor any of its retailers.
Old Aug 26, 2009 | 07:28 AM
BABY NSX's Avatar
So... got the catalitic converter installed this morning and the system is now all buttoned up. My first impression was this:
It's way too F**king loud!
I'm going to try installing the but plug later but there is no way you could daily drive this as it is. I mean... its sounds awsome and makes the idle with the pro1 cams very very cool. but after driving around for about 45mins my ears are ringing, and that is without stepping hard on the throttle once.
I hand inserted the but plug and it does seem to cut the noise down alot so I'll give that a try later.
Another observation was that was my 02 sensor was recording fairly lean numbers when ever I would get on the gas a little (and pull the ECU out of closed loop). This tells me that the VE has gone up which means more power wich is a good thing A small tune up session will be needed before I realy see what this setup can do.
some more pics from today:
Cheers,
Doug
Old Aug 26, 2009 | 11:14 AM
00MRSi's Avatar
What kind of cat? I know Vibrant is located in the Toronto area..
Old Aug 26, 2009 | 11:21 AM
BABY NSX's Avatar
I believe its a Vibrant cat... metal core.
Old Aug 26, 2009 | 12:48 PM
1.5Slowmatic's Avatar
why not install a resonator inline instead of installing the silencer? a good 30" long res. should really help cut down on the noise
Old Aug 26, 2009 | 01:45 PM
BABY NSX's Avatar
Maybe an option down the road for sure... but for now I'm just going to leave it as it is. I'm just happy that the silencer is as effective as it is.
Old Aug 27, 2009 | 01:40 PM
4doorteggy's Avatar
that header looks like it has good clearance...good parts
Old Aug 27, 2009 | 08:22 PM
95skunkedgsr's Avatar
glad to know i wasnt the only lazy one that never put the scatter sheild back on the tranny lol
Old Aug 28, 2009 | 08:16 AM
BABY NSX's Avatar
Actualy... just ordered the GSR scatter sheild from Honda so that I can cover it up. the OE ITR tranny brace doesn't quite fit with this header. I'll be modifying it shortly but in the mean time I don't want to drive around with my flywheel exposed like that... Not a good idea.
Cheers,
Doug
Old Aug 28, 2009 | 08:43 AM
91jdmhatchback's Avatar
are those stamped collectors on the skunk header?
Old Aug 28, 2009 | 10:02 AM
BABY NSX's Avatar
They look like they are; however, when looking down the collector opening they look like they do a good job of blending the primaries together.
Old Aug 28, 2009 | 08:08 PM
it took skunk a long time for this header to come out, i think its a pretty good bang for the buck header
Old Aug 28, 2009 | 09:43 PM
Jimmy's Avatar
Global Moderator
Nice.
Photo quality
elementwong
Sep 24, 2016 04:59 PM
weiRtech
Welding / Fabrication
21
Oct 14, 2009 09:47 PM
SilverWarrior
Oct 18, 2007 11:06 PM
phantasticphan
Feb 6, 2007 12:35 PM
