92 integra running issue
Old Aug 25, 2009 | 08:45 AM
SleepyHatchZ6's Avatar
Default 92 integra running issue
The problem im having is when i turn on the car it starts right up, but if you stomp on the gas it dies, BUT if you press the gas slowly its fine, after it dies it take a few tries before starting back up. it has brand new spark plugs wires and valve cover gasket with grommets, everthing is bone stock except someone put a stupid aftermarket filter on the stock tubing and it burns white smoke out the tubing need help seriosuly have no idea and its a daily driver thanks guys.
Old Aug 26, 2009 | 07:23 AM
Default Re: 92 integra running issue
wow 23 views and no one can even point me in te right direction if you need more info let me now i cant figure this out at all and cant find anything searching
Old Aug 26, 2009 | 07:38 AM
Circusraven's Avatar
Well...
What have YOU checked? maybe that would be a better start than saying "wow no one can point me in the right direction" People aren't mind readers.
Did you check your distributor? coil? timing? vacuum lines? fuel pressure?
Old Aug 27, 2009 | 05:46 AM
Ya checked fuel pressure, timing, vacuum lines but i havent checked dizzy cap and rotor i didnt think that cud cause the car to die upom acceleration but ill check it out thanks
Old Aug 27, 2009 | 11:09 AM
eaglewesman's Avatar
Some general maintenance ideas:
-Main relay (life of 10-15 years ~$60)
-Fuel filter (manual says replace once a year ~$30)
-Air filter (clean it out)
-Throttle body (spray and clean with TB cleaner)
White smoke out the tubing? Explain more, it sounds like you're burning something.
Max500
Jul 27, 2012 05:56 AM
jdm_sir2
Mar 31, 2008 10:05 PM
lbjoe
May 22, 2003 04:41 PM
Lonny
Apr 13, 2003 01:12 PM
