gsr parts compatible on b18b
Old Aug 24, 2009 | 11:54 AM
integra3586's Avatar
Default gsr parts compatible on b18b
Throttle Body from B18C1 fit on B18B
Distrubutor from B18C1 work on B18B
Fuel Rail From B18C1 work on B18B
IAT sensor from B18C1 work on B18B
Im installing a B18B into my 1994 GSR, But the b18b is missing quite a few pieces. is any of this stuff compatible?
also will the p72 ecu be able to run the b18b? I have a chipped ecu if i need to use it, but i dont want to have to worry about burning a base map.
Old Aug 24, 2009 | 12:36 PM
sixfourkiller's Avatar
Default Re: gsr parts compatible on b18b
i know that your distrubutor from your b18c1 not going to work for your LS motor b18b1. and yes your ecu can run the ls motor but it might need to be reprogram cuz it might not run rough when u get to like 4500 rpm or when the vtec need to kick cuz its going to be a bit differents mapping and u dont have vtec
Old Aug 24, 2009 | 12:40 PM
what about the throttle body? or fuel rail?
Syphon
Jul 26, 2003 02:08 AM
Toby1
Mar 29, 2002 11:46 AM
