Good Bye Honda For Sale Thread (thieves) JDM B18C, LSD, WR Race Header, Typer R, etc.
Old Aug 24, 2009 | 11:17 AM
CivicGSR225's Avatar
Default Good Bye Honda For Sale Thread (thieves) JDM B18C, LSD, WR Race Header, Typer R, etc.
**Prices Reduced 9/15/2009**
***Prices Reduced again on 10/1/2009***
Hello Everyone,
Here is some quick background information. I was getting ready to install all of these parts into my beautiful bone stock 1995 Civic SI after two years of ownership. However, last week my car got stolen from my house, stripped, and then recovered. As much as it breaks my heart because the car was immaculate and I know I will never find another one as clean, it is somewhat of a blessing in disguise because I was literally about two weeks away from installing all of these parts. Everything must go. I am not taking the chance again by buying another Honda. If I cannot even keep a stock Honda from getting stolen, then a modified one is absolutely out of the question. Prices are somewhat negotiable, but I need to do my best to make back the money that was already spent. So if your offer is way below what I am asking, then please do not waste my time or yours. Please feel free to PM me with any questions. Telephone contact for any serious inquiries available upon request. I am located in CT. Thanks!
My goal for this swap was 190 - 200WHP Naturally Aspirated without touching internals (Except Mugen higher compression Head Gasket +.4). I basically have everything here to achieve this except for an Intake Manifold, which I was able to cancel the order for because it had not shipped yet when the car got stolen. I am very meticulous and careful when it comes to selecting parts. All these parts were chosen for their quality and proven performance capabilities. You will not find any cheap or poor condition parts here.
First item is an immaculate JDM B18C GSR engine with an 4.4 Final Drive LSD transmission. I was very reluctant to by a motor from a private party. This motor was originally purchased by a local member from an importer, but it was never actually installed or ran in any US car. I confirmed this by e-stalking him. His story matched his past two years of Honda-Tech posts. As you can see by the pictures, the motor is extremely clean and looks practically brand new inside. At this point, I am going to try to sell the motor as a complete swap.
Swap includes:
- JDM B18C GSR Engine (180 HP and 126 Torque, 10.6:1 Compression)
- Hydraulic 4.4 Final Drive LSD Transmission
- ECU (USDM Virgin P72)
- Brand New Axles
- USDM Integra Type R Shift Linkage
- Alternator
- Starter
- Brand New ACT Extreme Pressure Plate (Can remove Clutch and PP upon request)
- Brand New ACT 6 Puck Clutch (Can remove Clutch and PP upon request)
- OEM Flywheel (Have a brand new Fidanza 7lb Flywheel BNIB also, see below)
- Intake Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness will all required sensors
- A/C Compressor
- Power Steering Pump
Engine and Transmission have been sold!!!
I also have over 400.00 worth of all Brand New Sealed Genuine OEM Honda Maintenance Parts that I purchased to install into the engine before putting it into the car. I have the following:
Taken straight from my receipt from Honda Parts Unlimited:
15825-P08-005 FILTER ASSY., SPOOL VALVE $12.36 (VTEC Solenoid)
(Not Taxable) 1 $12.36
36172-P08-015 GASKET, VTEC SOLENOID BASE $5.12
(Not Taxable) 1 $5.12
90026-PE0-000 BOLT, STUD (8X37) $2.32 (Exhaust Studs)
(Not Taxable) 9 $20.88
90212-PD2-003 NUT, SELF-LOCK (8MM) $1.59 (Exhaust Manifold Nuts)
(Not Taxable) 9 $14.31
14400-P72-014 BELT, TIMING (126RU26) $42.92
(Not Taxable) 1 $42.92
91213-PR3-004 OIL SEAL (29X43X8) (ARAI) $4.92 (CAM Seals)
(Not Taxable) 2 $9.84
91214-PLE-003 OIL SEAL (80X100X10) (NOK) $11.63 (Rear Main Seal)
(Not Taxable) 1 $11.63
94109-14000 WASHER, DRAIN PLUG (14MM) $0.22
(Not Taxable) 1 $0.22
12030-PR3-000 GASKET SET, HEAD COVER $37.73
(Not Taxable) 1 $37.73
30102-P72-006 CAP ASSY. $17.42
(Not Taxable) 1 $17.42
06304-P72-000 KIT, ROTOR HEAD ASSY. $16.11
(Not Taxable) 1 $16.11
30110-PA1-732 O-RING (26.4X3.1) (TEC) $1.31
(Not Taxable) 1 $1.31
12513-P30-000 RUBBER, CYLINDER HEAD SEAL $4.76
(Not Taxable) 1 $4.76
12210-PZ1-004 SEAL A, VALVE STEM (NOK) $1.07 (Intake Valve Seals)
(Not Taxable) 8 $8.56
12211-PZ1-004 SEAL B, VALVE STEM (NOK) $1.07 (Exhaust Valve Seals)
18115-P30-013 GASKET, EX. MANIFOLD (NIPPON LEAKLESS) $11.77
(Not Taxable) 1 $11.77
32722-P30-405 WIRE, IGNITION (SUMITOMO) $49.58
(Not Taxable) 1 $49.58
19200-P72-003 WATER PUMP $84.26
(Not Taxable) 1 $84.26
37870-PJ7-003 SENSOR ASSY., WATER TEMPERATURE (TW5) (MATSUSHITA) $25.69
(Not Taxable) 1 $25.69
19301-P08-316 THERMOSTAT ASSY. (NIPPON THERMOSTAT) $15.19
(Not Taxable) 1 $15.19
91314-PH7-003 O-RING (31.2X4.1) (NOK) $1.45
(Not Taxable) 1 $1.45
91205-PL3-A01 OIL SEAL (35X56X8) (ARAI) $6.56 (Axle Seal)
(Not Taxable) 1 $6.56
91205-PC9-711 OIL SEAL (40X62X8) (NOK) $7.70 (Axle Seal)
(Not Taxable) 1 $7.70
16176-P30-004 GASKET, THROTTLE BODY (NIPPON LEAKLESS) $3.77
(Not Taxable) 1 $3.77
Subtotal Amount : $417.70
Discount : $0.00
Shipping (FedEx - Ground Home Delivery Domestic) : $0.00
Tax Amount : $0.00
Total $417.70
Everything is brand new and sealed.
I will sell the whole lot for $375.00
Brand New B-Series STR Polyurethane Motor Mounts.
SOLD!
Brand New Energy Suspension Master Kit for the 92-95 Civic w/extra Lube.
SOLD!!!
Brand New Weapon-R Tri-Y Race Header. This header makes almost identical torque to the Toda Header, but slightly higher peak HP. This was proven in the "Great Header Shootout" by Titan Motorsports. See dyno comparison below. Header only taken out of box for picture.
$440.00 shipped to anywhere in the lower 48 States!
Brand New Sealed Fidanza 7lb Flywheel.
$175.00 shipped to anywhere in the lower 48 States!
OEM Integra Type R Suspension with Lower Control Arms. Better shock valving and stiffer spring rates than standard models. Lowers the car slightly. A great discrete upgrade. Only 40k on them. Bushings are in excellent shape. The LCA's included are needed in order to install into a Civic or non ITR Integra. Direct bolt-on to any 88-00 Civic or 94-01 Integra.
SOLD!!!
Brand New Sealed Blox Intake Manifold Gasket. I was able to cancel the order for the actual Intake Manifold, as it hadn't shipped yet when the car got stolen.
$34.00 shipped to anywhere in the lower 48 States!
2 - Quarts of Honda MTF
SOLD!!!
RC Engineering 310cc High Impedence Injectors.
SOLD!!!
Discrete home made 2.5" exhaust for the 92-95 Civic Hatchback with cat eliminating header. Uses a Dynomax muffler.
$215.00 OBO
Mugen Compression Raising Head Gasket. Raises compression by .4. Adding this to the B18C which is 10.6:1, will yield a total of 11:1 compression.
$160.00 shipped to anywhere in the lower 48 States!
Discounts available for purchases on multiple parts!
Thanks for looking guys. Special thanks to all the wonderful people in the Honda world that have to ruin it for everyone else.
Old Aug 24, 2009 | 12:06 PM
eazybmx's Avatar
Default Re: Good Bye Honda For Sale Thread (thieves) JDM B18C, LSD, WR Race Header, Typer R,
what kind of deal could you do if i bought the swap, all honda seals and header off you?
pm me so we can talk and also where are you located?
Old Aug 24, 2009 | 01:31 PM
2001B18C1GS-R's Avatar
10 shipped on the mtf
Old Aug 24, 2009 | 01:54 PM
92egvx's Avatar
ttt
Old Aug 24, 2009 | 08:45 PM
killercannible's Avatar
Stop selling this ****, don't give up cause thats how the thieves win. Ct is a harder place to keep your car than people think! I live in the woods and i know someone who lost 2 cars in one year!
Old Aug 26, 2009 | 07:06 AM
Bump.
Old Aug 26, 2009 | 07:42 AM
BoostedCD6's Avatar
bump
Old Aug 28, 2009 | 07:22 AM
Morning bump.
Old Aug 28, 2009 | 08:25 AM
blade0314's Avatar
ill buy that tranny and mounts off you let me kno pm me
Old Aug 28, 2009 | 09:43 AM
Mounts I can sell you. However, for the transmission; I am not seperating any from the motor swap itself for the time being.
PM me if your interested in the just the mounts.
Old Aug 29, 2009 | 06:48 PM
To the top.
Old Aug 31, 2009 | 06:02 AM
Monday morning bump.
Old Sep 1, 2009 | 07:29 AM
Up up up.
Old Sep 2, 2009 | 05:24 PM
Bump.
Old Sep 2, 2009 | 07:27 PM
jtegg90's Avatar
if i've seen u last yr. i would buy this swap quick...sorry to hear about ur car got stolen....
Old Sep 4, 2009 | 08:27 PM
Weekend bump.
Old Sep 6, 2009 | 05:00 PM
The Energy Suspension Bushing Kit and Honda MTF have been sold!
The Mugen Head Gasket has also arrived
Old Sep 6, 2009 | 06:31 PM
negusjuda's Avatar
if u decide to part the motor out i would get the long block as i cant use the hydro tranny i have a da
Old Sep 8, 2009 | 05:35 AM
Tuesday morning bump. Hope everyone had a nice holiday weekend.
Old Sep 10, 2009 | 05:38 AM
Motor mounts have been sold!
Old Sep 14, 2009 | 05:21 AM
Up.
Old Sep 14, 2009 | 08:18 AM
efvader's Avatar
good parts, what part of ct it get taken?
Old Sep 15, 2009 | 05:21 PM
Prices reduced as of 9/15/2009!
Old Sep 16, 2009 | 03:33 PM
Up up up.
Old Sep 19, 2009 | 05:01 PM
Bump.
