D16Z6 Block+ D16Y7 Head= Disaster Timing???
Old Aug 24, 2009 | 10:00 AM
ekwolf1986's Avatar
Default D16Z6 Block+ D16Y7 Head= Disaster Timing???
i know its a silly question but... a friend did this combo when trying to build a vitara piston based "Boost Setup". however upon completion... his timing just wouldnt get on point. it would run and seem to lose the timing halfway down a block...so thats why im asking... will the d16y7 head throw off the z6 block or what. Thanks For Dem Feedbacks Mayne.
Old Aug 24, 2009 | 10:29 AM
mother ef-er's Avatar
Default Re: D16Z6 Block+ D16Y7 Head= Disaster Timing???
maybe timing belt wasnt tensioned poperly? if he had vitaras in a boosted motor it sounds like he knows alot about what hes doing though.. you may have to get an adjustable cam gear to compensate fo head height. im not sure though. the block should except the head with no problems.
but why the y7 head on a z6 block? im just wondering what the benifits would be? higher/lower compression than stock z6?
but good luck man!
chuckieD
Feb 24, 2010 09:08 PM
egcivic
Nov 7, 2007 01:35 PM
pinoy369
Apr 24, 2007 06:00 AM
Jayboy
Apr 23, 2005 03:43 PM
