As much HELP AS I CAN GET
Im looking to do a swap from a automatic to a manual 5 speed i don't know what motor setup would be the best i have a 2000 automatic ex vtech sohc and i just got i tpainted and the body completley redone i know i need a shift linkage and a new computer to go with the motor but do i need to change my wiring harness or what do i need to do as far as the other stuff as much tips would help me the best... thanks guys
huh? are you doing an engine swap or just a transmission swap to a 5 speed?
engines are compatable with 5 speed and automatic transmissions in case you didnt know...
ok well then ill be a typical forum guy and say search... the possibilities are endles... use the search button and the FAQ section on this thread... then ask questions if your still not sure
you can get a fresh used JDM 5 speed tranny on ebay for less than $500 shipped and they work great. They even have slightly different gear ratios that may make the car slightly quicker.
good luck
good luck
Fernando123456eclipse
Jul 12, 2008 07:50 AM
Honda-Hooligan
Feb 25, 2004 05:39 AM
