Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
ABS
Old Aug 24, 2009 | 05:17 AM
Whatislove's Avatar
Default ABS
One of the ABS sensors aint working right so my ABS light is on most of the time. Every now and then the light would go off and ABS will start working again but start to kick in anytime I break for no reason.
I dont care to find out which sensor it is or get it fixed anytime soon.
What is the best way to temporary disable ABS.
1. Unplug one of the sensors
2. Remove the ABS fuse
Old Aug 25, 2009 | 01:44 PM
Whatislove's Avatar
Default Re: ABS
Anyone have an answer to this?
Old Aug 25, 2009 | 02:54 PM
theineffable's Avatar
Default Re: ABS
is it just me or do you have a new problem w/ your car every couple of weeks?
i'd try removing the abs fuse?
Old Aug 25, 2009 | 06:32 PM
bomerman19's Avatar
Default Re: ABS
remove the fuse if you just pull one of the sensors then it will try to test the system everyonce in a while if you pull the fuse it will leave the light on but disable the abs the fuse is under the dash
Old Aug 26, 2009 | 05:20 AM
Whatislove's Avatar
Default Re: ABS
k thanks.
and yes, I'm having problems continuously.
Old Aug 27, 2009 | 02:49 PM
Janet@bisimoto's Avatar
Default Re: ABS
Originally Posted by Whatislove
k thanks.
/\/\ You got some humor. Lol.
Old Aug 29, 2009 | 12:11 AM
aLlmoTorcoUpe's Avatar
Default Re: ABS
hey will this effect any thing if u take out the fuse from the abs?
Old Aug 29, 2009 | 08:35 PM
bomerman19's Avatar
Default Re: ABS
it will just turn the abs light on and the abs won't work your brakes will work fine some times it will also trigger the hand brake light
///Apex
Jul 15, 2011 02:25 PM
cslegacy
Sep 11, 2007 03:36 AM
m1northreat
Honda S2000
Mar 12, 2007 10:08 PM
vti444
Sep 6, 2004 12:44 PM
ArchAngel Sabastian
Jan 20, 2003 04:49 PM
