Has anyone ever installed window switches on manual panels?
Old Aug 24, 2009 | 12:52 AM
fryman's Avatar
Default Has anyone ever installed window switches on manual panels?
I bought the front window switches for my eg Civic sedan and I was going to cut a hole for them instead of buying power window door panels but the space they should go looks too small for them to fit.
I know this has been done on coupes but has it been done on sedans?
If so does anyone have pictures?
Old Aug 24, 2009 | 07:08 AM
shoklid's Avatar
Default Re: Has anyone ever installed window switches on manual panels?
well anything CAN be done depends on how ur fab choices are. id just buy new panels froma junkyard and call it a day
Old Aug 24, 2009 | 09:30 AM
redrocket's Avatar
Are you talking about the driver's switch or passenger's? i just mounted my drivers switch on the outside, by poking 4 holes in the panel & tying it down just in front of the door handle. The wires run through the orig crank hole. it may look shitty, but it works. Seems to me the door panels are the 2nd thing to disappear off a junk car, after the ECU. If by some miracle there IS a door panel, its all effing dirty & greasy & torn up.
Old Aug 24, 2009 | 09:37 AM
fryman's Avatar
I bought both the driver side master switch and the front passenger switch.Can you post pics of what you did?
JAD
13
Oct 1, 2016 04:05 PM
hardrock2401
Dec 21, 2013 06:03 PM
:jdmshmaydm:
Aug 31, 2010 07:34 AM
tpcostello
Jun 23, 2005 02:29 AM
