92 Accord No Power to Fuel Pump
Old Aug 23, 2009 | 06:07 PM
Motoxxxracer096's Avatar
New User
Default 92 Accord No Power to Fuel Pump
It's a 92 Honda Accord. Had an intermittent no start issue that is fuel related. First thing I change the fuel pump. Then I put everything back together and Im getting no power at the pump. I also changed the main relay. Still no power at the pump and the fuses are good. Everything is plugged in and hooked up. Pump works fine when I jump the pump with power. Only thing I found suspicious is there is a gray connector I found in the trunk plugged into nothing, but I don't see another harness to plug into it.. does anyone know if this plugs into anything, because the harness runs from the pump to the brown connector (guessing it is for fuel gauge). from there it goes into the trunk and splits off between the gray mysterious connector and then it grounds. Any help?
Old Aug 23, 2009 | 09:11 PM
alkoholikwun's Avatar
Default Re: 92 Accord No Power to Fuel Pump
pics of where plug is
Rodnie1919
Classic Hondas
Jul 25, 2020 09:07 AM
Bail2good
Mar 27, 2020 11:14 AM
Dobird78
Oct 9, 2013 05:51 PM
logjammin
17
Jul 29, 2013 07:59 AM
richardekirby
Jul 5, 2007 09:19 PM
