How to tighten JRSC supercharger belt?
Old Aug 26, 2002 | 08:07 AM
redintegra's Avatar
Default How to tighten JRSC supercharger belt?
I'm getting belt squeal at high rpms and losing boost. I wanna tighten my supercharger belt but not sure how to do it. I have an Integra JRSC.
Do I just loosen the nut on the 10mm adjustment bolt and tighten the bolt and then retighten the nut? Do I have to loosen the bolt on the idler pulley as well?
Thanks in advance
Old Aug 26, 2002 | 08:45 AM
Double 06's Avatar
New User
Default Re: How to tighten JRSC supercharger belt? (redintegra)
I would probably ask around here, maybe someone has the new link to the hostboard (JRSC discussion board), i can't seem to access it no longer.
its been such along time since i've had the supercharger i can't remember, but i remember replacing and tightening the belt on the POS charger.
Old Aug 26, 2002 | 09:16 AM
JT's Avatar
JT
Yes, you will need to loosen the bolt on the idle pulley as well.
Old Aug 26, 2002 | 09:21 AM
hypa's Avatar
http://www.hostboard.com/cgi-bin/ult...bb=forum&f=110
the new hostboard link.
To tighten the belt, you need to do the steps you mentioned. You will also need to loosen the bolt behind the idler pulley, so the arm can swing.
Old Aug 26, 2002 | 12:05 PM
Rory Breaker's Avatar
Exactly...there 2 bolts, one facing the passenger side and one facing the drivers side. You need to loosen these bolts, and then the arm with the idler pulley will be free to move. Push down on the pulley and retighten the bolts, then use the 10mm screw to keep the pressure on the idler pulley onto the SC belt.
JDMBOLONI
Nov 13, 2004 10:41 AM
DeDonDeRosa
Mar 14, 2003 04:06 PM
satan_srv
Aug 27, 2002 01:21 PM
EVIL Hx Coupe
May 22, 2002 02:19 PM
