OK here goes! CODE 20?
Old Aug 23, 2009 | 07:34 AM
lsvtec hf's Avatar
Default OK here goes! CODE 20?
OK need some help here. The chassis is an 91 CRX HF. I have an lsvtec that we just converted to obd-1. Used the RYWIRE conv. harness. Used a JDM P30 ecu. Touched the two wires that read the cel's. I have 2 long flashes. Am I correct it being code 20?
Code 20 is ELD. Anyone else run into the same code? Did some searches and could be grounds, Alt, etc.....NO codes when the two wires are touching. THANKS
Old Aug 23, 2009 | 09:13 AM
black0hatch's Avatar
Default Re: OK here goes! CODE 20?
yes 2 long flashes is 20. check the engine harness ground.
Old Aug 23, 2009 | 03:44 PM
lsvtec hf's Avatar
OK Anyone else have any suggestions?
Old Aug 23, 2009 | 03:49 PM
Crx Jimmy's Avatar
check the pinouts. make sure the stock harness eld wire does infact go to the proper spot on the conversion harness and into the new ecu.
Old Aug 23, 2009 | 03:53 PM
Crx Jimmy's Avatar
also if you were running obdo with the ls vtec before you did the obd1 conversion the eld wire is cut or removed because in that spot the obd0 vtec wire goes. so its possible the wire is switched in the harness before the jumper. this would only be the case if you were using a pr3 or pw0 ecu before. they do not have eld and have the vtec wire in the pin others ecus would use for the eld.
Old Aug 25, 2009 | 07:09 AM
SETI20's Avatar
The simplest solution would be to just eliminate the ELD check in the ECU.
Old Aug 25, 2009 | 07:29 AM
jlicrx's Avatar
actually, the PR3 and PW0 have the knock sensor at ECU pin B19, which is the same location as the ELD on the USDM ECUs
4g hatch
Jun 26, 2014 09:43 AM
doctorake
Mar 25, 2012 08:01 AM
CRX91SE
Sep 18, 2010 03:06 PM
jakscivic
35
May 12, 2007 04:32 PM
NipponRacing
Jun 18, 2002 05:49 PM
