Need help with manual window
okay on my hb my window wasn't rolling up right or at all for that matter
so i replaced the regulator in it. so now to the problem
it rolls up and down, when it all the way up and i roll it down the front seems to fall a little bit.
same is true the other way, when it all the way down and i go to roll it up, the front does not go up as fast as the back, and the back of the window pokes outside the car if i just roll it up normally.
im thinking it is the window tracks bent/broken but wanted some second opinions before buying some
anyone else have this problem?
any input is appreciated
the tracks are adjustable (a little bit)
as well as window position on the regulator.
try adjusting them and see what happens.
make sure all your bolts are tight.
also grab some shinetsu grease and lube the window channels.
did you buy the regulator used? if so it might be bent. but before assuming something is bent, try what i said.
Yeah i adjusted the window position on the regulator, and i bought the regulator new from honda.
everything has been grease and tightened
i did not know that the track was adjustable though. will definitely look at that tonight, thanks man
loosen it and you can adjust how tight the channels are.
sounds to me like the window is binding in the channel, causing it to lift out.
jdmztrane
11
Jun 23, 2010 08:04 PM
rasinhell
May 20, 2005 12:38 AM
