Suspension & Brakes Theory, alignment, spring rates....
eg shock install on ek
Old Aug 22, 2009 | 11:14 PM
la_teta's Avatar
Post eg shock install on ek
ive always known that the EG, EK and DC chassis have pretty much the same mounting points and suspension. so someone is trying to sell me a set of tein type flex coilovers for a great price but its for an EG.
I know they will fit on my EK but im not sure what kind of modification id have to make if any. has anyone here done this ? plz tell me what i have to do
Old Aug 23, 2009 | 01:33 AM
STOCK_SOHC_DX's Avatar
Default Re: eg shock install on ek
You will have to use washers for the rears. If you did a search on this it would have a billion results.
Old Aug 23, 2009 | 07:39 PM
drag_killer's Avatar
Hi bro,
You have to change rear lower arm to EG model, then it will fit
Old Aug 23, 2009 | 08:40 PM
Originally Posted by drag_killer
Hi bro,
NO! EG arms are longer than EK arms.
Old Aug 23, 2009 | 09:55 PM
Egezzy's Avatar
Spongebrad Squarepants
vice versa. but the answer is still no. that would change your camber curves..motion ratio..wheel rates..etc.
Old Aug 23, 2009 | 10:55 PM
my bad I thought the eg was longer.
Old Aug 24, 2009 | 03:49 AM
batallic's Avatar
fronts will work, rears will need washers since the EK LCA is thinner than the EG-DC
ekb16a
Oct 29, 2009 01:52 PM
Momentum
Suspension & Brakes
May 6, 2009 10:11 PM
1 jonesie
May 20, 2007 05:08 PM
J. Tippy
Suspension & Brakes
May 18, 2007 11:08 AM
RHDintegXsi
Suspension & Brakes
Mar 11, 2005 08:38 PM
