Heater not blowing? climate control?
Old Aug 22, 2009 | 09:06 PM
Chewy Built !'s Avatar
Default Heater not blowing? climate control?
I just started having this problem after a new swap.
96 honda civic coupe with D16y7.
Ill have the car on for about 30 mins, and the heater starts to blow hot, then cuts off. As i step on the gas to raise the rpm, the heater starts blowing hot again.
Heater core is good, blower is good, all the hoses are warm, thermostat is gone.
Im thinking my water pump going out?
any info would be appreciated.
Also, any one have a pic of where the wire that moves the "cold/hot" on the climate control goes to? i did a dash swap, and i think i ripped this beeesh out., the one that connects to the bottom of the blower
Old Aug 24, 2009 | 08:47 PM
Default Re: Heater not blowing? climate control?
bump
Old Aug 24, 2009 | 08:53 PM
Former User's Avatar
Top off the coolant in the reservoir and radiator and then bleed the cooling system:
(Procedure may take 20-30 minutes)
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (your engine does not have a bleed bolt so skip that step below):
Old Aug 24, 2009 | 08:57 PM
Old Aug 25, 2009 | 09:45 PM
redrocket's Avatar
are you saying the blower stops blowing anything? or does it blow hot, then blow cold, then you hit the gas & the air is hot again?
EJ6_Oatmeal
17
Mar 10, 2014 03:11 AM
playertwo
Dec 13, 2011 02:36 PM
supertiggy
Feb 26, 2009 09:15 AM
grkblood13
Dec 7, 2008 03:30 PM
zerogravitycrx
Dec 6, 2004 01:34 AM
