gsr only runs with map unplugged
got a 95 cx with an 97 gsr in it, has had alot of problems finally we got it down to running and driving only if the map sensor is unplugged. im running a virgin p28 could that do it?
it probably is because you are using the wrong ECU... Did you ever think of that???
Unplugging the MAP make it run way rich, so its no surprise that it will start-up now.
yea forget iabs for now im chipping a p28 as we speak with a p72 basemap and no i dont belive so i switched them around to see but still nothing and yea its running rich but least it moves haha so once i got the chip in itll run with the map plugged in?
the runners will stay open if you cap off the vac on the diaphragm, you won't even throw a check engine light.
p28 doesn't have the right timing and so on. try getting to run good on the correct ecu, or not your choice man.
hope i helped, but the p28 isn't gonna help and the rev limiter is at 7400 rpm's ? gsr peeks at 7800-7900 and the p72 rev's past it
yea with a p72 basemapeverything should run right? i understand what your saying thats why i got 2 p28s one from chipping other for testing since its still untouched
QuickDxEk
11
May 31, 2007 01:45 PM
