Just swapped my motor, feels like no clutch
Ok so I just swapped my d15b7 today for a d15b. Got the motor and new transmission in and all hooked up.
Turned the key and the motor started up great first try. The problem is that it doesn't actually move.
It feels like there is an absence of a clutch all together. Any idea what could cause that?
Well technically it's not on the engine. But i'm not totally sure if the clutch is in. I was told that it was already in and i never seperated the motor and tranny when i put them in. Going to check it now. Will be back to report results later.
check to see if the hydro cable is in the correct spot of your clutch fork.
if your axle's aren't in all the way you need to check and make sure you didn't sheer off the splines on the end of your axle, if you did, all that metal needs to get flushed out. and you'll need a new axle
86azms3
May 11, 2015 04:44 PM
LSVtechnologytur...
Aug 17, 2005 07:18 PM
