hasport motor mount question
Old Aug 22, 2009 | 03:30 PM
Luke G.'s Avatar
Default hasport motor mount question
if i got those motor mounts would i not have to use the two front lower mounts?
Old Aug 22, 2009 | 03:33 PM
GSaura's Avatar
Default Re: hasport motor mount question
You don't have to use them even with stock mounts. I have the 88a's and use stock lowers but they're not necessary. Are you trying to clean up the bay some?
Old Aug 22, 2009 | 03:34 PM
Luke G.'s Avatar
oh really? i was wondering because one of the holes is drilled out and very big, i dont wanna deal with re tapping it and all that, so i dont have to use them?
Old Aug 22, 2009 | 03:37 PM
GSaura's Avatar
No you don't have to use them. Most people's torque mounts are broken anyway. Are you sure you were looking at the right holes? There's a bigger hole on each side that isn't threaded.
GSaura's Avatar
as in you only have to use two bolts on each side
Old Aug 22, 2009 | 03:39 PM
Luke G.'s Avatar
yea i was looking at the right ones, the originals were rusted and were stuck, i had to drill them out, this is a jdm b18c going into my 93 civic chassis.
Old Aug 22, 2009 | 04:16 PM
Ej8_KiD's Avatar
get some hasports or innovatives and ditch the torque mounts
Old Aug 22, 2009 | 04:23 PM
steveo135's Avatar
i Have innovative mounts with new oem torque mounts and an ingalls torque damper !
Old Aug 25, 2009 | 01:31 PM
Hasport's Avatar
read this post completely and the answer is yes you would still run them
https://honda-tech.com/forums/showth...light=hasports
Old Aug 25, 2009 | 01:56 PM
98civdx's Avatar
Master Detailer
you dont have to have them, but id still run them.
inless someone can give you a good reason not to.
92lxsleeper
Jul 29, 2009 08:28 AM
1LowSol
16
Jun 13, 2009 12:54 AM
ten2doyle102
Aug 6, 2008 05:11 AM
Slowass4dr
16
Aug 12, 2005 06:51 PM
