Suspension & Brakes Theory, alignment, spring rates....
SPRING QUESTION [NOOB ALERT]
Old Aug 22, 2009 | 02:38 PM
CLIPHSET's Avatar
Default SPRING QUESTION [NOOB ALERT]
Alright so about 4 months ago I bought my DC and it has Apexi Coilovers and was at stock height I'm guessing. My friend and I dumped my car to the lowest it would go (I have about 2.5-3" to the floor and my front lip) a little after buying the car and today I just put in my camber kit. I noticed when I was putting the camber kit on that the springs were super loose like they were even installed correctly. So I'm guessing that those springs were only good for the height I bought my car at. So now I have a strong feeling I need new springs, just not sure what type of springs I need and what would be the best type for daily driving. If you can please help a noob @ suspension please.
Thanks!
Old Aug 23, 2009 | 05:59 AM
sicones's Avatar
Default Re: SPRING QUESTION [NOOB ALERT]
If the springs came loose when you jacked up the car then you are riding to low. If you want to continue killing ride quality get helper springs.
Old Aug 23, 2009 | 06:41 PM
McCormick's Avatar
you probably adjusted it so far out that it is just riding on the struts. i was try to readjust them.
Old Aug 24, 2009 | 07:53 AM
alphalanos's Avatar
Theyll be loose at full droop because they are shorter. When the cars on the ground the spring compresses.
Old Aug 24, 2009 | 08:30 AM
Egezzy's Avatar
Spongebrad Squarepants
yes. depending on ride height and spring length.
Old Aug 25, 2009 | 09:53 AM
9000k's Avatar
New User
On my jic magic's there are two ways to change ride level
EM2_touge
Honda Civic (2001 - 2005)
12
Jan 31, 2009 01:41 PM
prostreetonline
16
Aug 11, 2005 05:54 PM
SiCrxer
May 24, 2004 08:46 PM
binkster
Apr 11, 2003 02:59 PM
SpoonSpecR
Apr 6, 2003 02:44 PM
