Sunroof jammed?
My sunrrof appears to be 10% open. It won't open or close...maybe because its lacking the proper fuse but how do i get to the motor to see if something is screwed up there? Needed to repair damn near everything is hard when you don't know anything.
Nick
Nick
You can use an allen wrench to open and close it. Look at the head liner behind the sunroof, and pull the small circle out. You'll see what i mean then.
The sunroof switch commonly goes bad.
I tried opening it with the wrench but the front of the sunroof wont budge. I took out the switch and sanded down the contacts and still nothing. No sounds, no noises, no nothing. I wish I knew what fuse went to it. I wouls WD40 the rails but I cant move the damn thing.
Nick
Nick
