Help, BLOX or SKUNK2
let me show you what im doing here.
This is my car right now,
the gold on the rotas is a kindof a flatish gold but not a extremely flat gold...hahah if you know what i mean.
anyways this is exactly what i want to do under the car,
now my question is should i go with the SKUNK2 lower control arms in gold
or the BLOX lower control arms in gold
im on a budget and the blox is way cheaper but i want the best so if any one has had any of theses is the gold what i want and what do you think of them? sorry for the pictures being different sizes
ive had blox lcas on my ej8 and the bushings went bad in about 5-6 months. i would suggest you spend the extra money for the skunk2 lcas, they will probably last longer.
most if not everyone would choose skunk2 only because of the ''NAME'' but dont let that fool you. my bro has gold s2 control arms and his bushings went out. so my point is, regardless of what you get, s2 or blox,you are still gonna run into the same problems with both. so just go with the one you like the most or one that fits your taste and budget.
i bought a pair of blox lca, say 3yrs ago when i was doing the rear brake disc conversion, and now the bushing started to tear. i get this squeaky noise from the rear but can't figure out if the lca bushing is causing it or not..i grease up the blox bushing pretty good but still squeaks..i'm planning to get the skunk2 lca later..hopefully it'll be better..plus i lost the receipt to the blox lca so can't get warranty out of it..although i don't think they cover the bushing since it's a wear-and-tear piece.
Blox suck, I bought a set and the bushings went bad in under 3k miles even though I clocked them and torqued all my fasteners to spec.
I haven't had any issue with ES bushings in OEM LCAs, so I spray painted a pair silver and put new black bushings in. They look sexy.
allricedout
50
Jul 20, 2008 05:50 PM
EnjoyTheRideDC2
Jan 10, 2007 10:36 PM
