timing off one tooth
Old Aug 22, 2009 | 06:16 AM
jdmthug's Avatar
Default timing off one tooth
im having a problem with my motor..a buddy and i are putting a new timing belt on and have realized that the timing is off by one tooth..im assuming this cannot be good..the crank and the cams are off..my question is am I able to replace the timing belt water pump tensioner with the alignment like this or do i have to get everything lined up correctly in order to do this can anyone guide me in the right direction..the setup is a b18a1 block
Old Aug 22, 2009 | 06:31 AM
Leady's Avatar
Default Re: timing off one tooth
Line everything up the right way or you'll run into trouble you really don't want to deal with.
Old Aug 22, 2009 | 06:41 AM
sde780's Avatar
You don't have to line it up to replace, just make sure when you put it all together it's perfectly lined up or else it'll run like ****
Old Aug 22, 2009 | 07:09 AM
GSaura's Avatar
Have you done a timing belt on an integra before? Sometimes, it looks like it is off, but it isn't. Like the pointer on the crank pulley will be slightly below the pointer on the timing cover with the cam gears matched up. If it's off by a tooth, there will be a big difference between the timing cover pointer and the crank pulley indicator.
As long as you make sure it's as close to TDC as you can get it before changing the belt, you can always turn the cams with a wrench or turn the crank pulley to get it lined up for the new belt.
Bob_760
Jan 30, 2008 02:48 PM
efyou
Jul 1, 2006 10:07 AM
Danronian
Apr 12, 2006 03:06 PM
deSigi
May 15, 2005 06:46 PM
Carp
Oct 15, 2001 11:05 AM
