Rotor over hub coversion question
I have a 94 accord Ex
I was wondering if this set up will work
Prelude 4th gen Vtec 11.1" Rotors(They are rotor over hub)
GS sedan 2 piston calipers
T25 caliper bracket
1998 Acura 2.3CL Front Hubs OEM part # - 44600-YS8-A00
1990-1998 Accord Front wheel bearing OEM Part # - 44200-SM1-008
Mainly asking will the prelude rotor work? I know people have done the rotor over hub, but keeping the 98 acura Cl 10'' rotors. Why not upgrade rotor size if its about the same price?
T25 caliper bracket
Did you read the Accord FAQ or search?
I know I've posted it multiple times in other threads from the AccordinglyDone Brake Setup thread over to here.
The accordingly form link doesnt work anymore and nothing was said about using the 11.1'' Prelude rotor on the HT write-up. A 10'' CL rotor was used. But thanks for the USELESS info that you ALWAYS provide
*edit* and I REALLY mean 5 seconds of searching. I logged on, typed "brake upgrade" and "NSX" and there you have it, top 2 hits
http://www.accordinglydone.com/forum...&highlight=NSX
****ing morons in this forum want everything spoon fed to them.
In case you're completely blind too
Dual-piston brake upgrade with rotor-over-hub conversion:
OEM Acura 98-99 2.3 CL front hubs
OEM Honda front calipers from 94-95 Legend GS Sedan
OEM Honda 23T brackets
rotors for 98-99 Acura 3.0 CL or 93-96 Prelude VTEC
pads - any options
Optional 94-97 Accord front wheel bearings
pads - any options
B16aCRXSi
Oct 31, 2008 02:32 PM
khunt0012
Feb 20, 2006 08:44 AM
