Help, Axel Leak
i have a odd leak comeing form were my driver side axel enters my transmission.. its seems to be some sort of seal..if i remove the axel is there a way i can replace the seal...???
Yeh if you remiove the axel you can replace the seal, you should also change the MTF while your at it. If that doesnt work then you have internal tranny problems possibly the carrier bearing.
so if i remove the axel from the tranny...the seal will be located inside the tranny houseing..?? and i can remove it with out taking apart the tranny correct..?
Drain fluid.
Pull axle.
Remove seal.
Clean case.
Install new seal.
Install axle.
Full with fluid.
No more leak.
Seal sits in the case right on the other side of the axle. Round black part.
Pull axle.
Remove seal.
Clean case.
Install new seal.
Install axle.
Full with fluid.
No more leak.
so how do you check if you have good carrier bearing?
I just let the dealer fixed my right axle seal leak way back April and 6 months after I have the same problem. Will this be an every six months problems that I have to deal with? How long should an axle seal last anyway?
