please proof my engine harness labels
Old Aug 21, 2009 | 06:05 PM
Turbo Dan's Avatar
Default please proof my engine harness labels
doing an d16a6 swap into my ef sedan dx.
so this is the dx harness out of my dx, i removed all the loom and tape and re wired it to include 4 injectors and dizzy wires.
i have an FITV valve on my intake manifold, so thats the reason i didn't skip that plug.
if anyone finds errors or can help me with the ?'s please post and let me know what they should be labelled as.
rywire eat your heart out
Old Aug 21, 2009 | 06:25 PM
4drEF's Avatar
Keyboard Humorist
Default Re: please proof my engine harness labels
"OIL?" under the "IAT?" is your thermo switch for the radiator fan.
The lug on the heavy white wire at the top left that you labeled 'ground' looks like the other end of the alternator wire. It goes to the power in the fuse box.
Where you have "?" near the "Dizzy" and "Oxygen" plug might be reverse connectors for the tranny and the oil and temp gauge connectors that go under the dizzy.
Old Aug 21, 2009 | 07:02 PM
Turbo Dan's Avatar
picture has been update to add mr "4drEF"'s suggestions
Old Aug 21, 2009 | 09:06 PM
4drEF's Avatar
Keyboard Humorist
The one you labeled for rad fan isn't the one I meant.
The connector you have labeled 'oil' that has 2 wires coming out of a black cover is the one for the thermo switch.
It's above the one you have labeled rad fan now and under th 'IAT?'
Old Aug 21, 2009 | 10:02 PM
424racer's Avatar
switch the rad fan sensor wire with the oil psi sensor wires...
good luck.
hammergunner
12
Aug 27, 2009 01:43 PM
Markis.
Jan 27, 2006 07:21 AM
Markis.
Jan 26, 2006 10:25 AM
PAsol_er
Jun 21, 2005 09:39 AM
fwpguy
Oct 9, 2003 06:27 AM
