Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anybody make a headlight scoop for an EF?
Old Aug 21, 2009 | 04:55 PM
brokenojoke's Avatar
Default Anybody make a headlight scoop for an EF?
I've searched and searched but didn't find anything. Come on honda-tech, you never seize to amaze me!
Only thing I've even found that's close is a generic nacaduct from Pegasus.
I'm interested in trying to fab up something like a "ram air box" using the passenger headlight as the inlet. If there is a design that already exists out there that would be nice.
Thanks
Old Aug 22, 2009 | 10:17 AM
chawski's Avatar
Default Re: Anybody make a headlight scoop for an EF?
I dont know of anyone that specifically sells them, but Ive made a few for relatively cheap. All I did was picked up a used light from a junk yard. Preheat your oven to about 350 and turn it off. place the light housing in the oven for 5-7 minutes until the butyl around the front lense gets soft. pry it off with a flathead. Then I cut out the back a bit to fit a 3in pvc pipe through to the intake. After that, stretch a piece of fleece over the entire outside of the light, glueing it to the perimeter of the front of the back of the housing and around the pvc opening. hit it with resin and maybe a layer or 2 of fiberglass matting. once its dry, cut out the hole from the inside of the pvc, sand it, hit it with some filler, sand again, and some krylon and youre set to go. Should cost you under 100, heck probably even 60
Old Aug 25, 2009 | 06:30 AM
thawley's Avatar
Check the drag race forum. It would be illegal for most of the popular sanctioned road racing classes.
Old Aug 25, 2009 | 07:11 AM
Lo-Buck EF's Avatar
Good to go for h1 and h2
Old Aug 25, 2009 | 08:42 AM
Slo-mo's Avatar
pictures? im one of those people that needs to see to understand
Old Aug 25, 2009 | 05:12 PM
Lo-Buck EF's Avatar
that headlight scoop, just on a honduh. im trying to find better pics, but i keep getting side tracked by all the bmw bling
Old Aug 28, 2009 | 07:07 AM
Good to go in ITE-u (scca) as well...... and for SWMS (nasa) classes I'm pretty sure. Those are the two that I'm concerned with.
Thanks for the replys guys. I think I'm just gonna make one our of fiberglass and post up some pics.
Old Aug 28, 2009 | 03:34 PM
chawski's Avatar
It looks almost exactly the same as picture on the blue bmw. unfortunately I dont have any build pictures
Old Aug 28, 2009 | 03:49 PM
Unfortunately the EF headlight uses two bulbs so the backing isn't ideal for a single hose inlet. It would work perfect for brake ducts though......
Old Aug 28, 2009 | 07:13 PM
smokin rubber's Avatar
not if you build a box around it
6. Prohibited Items (H1-H5)
a) Nitrous Oxide Systems.
b) Forced Induction (turbochargers, superchargers, ram air, etc).
c) Dry Sump Engine Oiling Systems
Old Aug 29, 2009 | 07:29 AM
One mans "ram air" box is another mans "cold air" box. How does the rulebook define a ram air box? Most have to incorporate a venturi, which mine would not have.
Old Aug 29, 2009 | 08:35 AM
chawski's Avatar
Its no biggy....just cut out the whole where you want the piping to go through and just fill the open spots just like you did on the front to make the scoop
Old Aug 29, 2009 | 09:47 AM
Good point......
Old Aug 29, 2009 | 10:40 AM
Lo-Buck EF's Avatar
i think we need to define ram air. i have seen some HC cars that have intake set-ups that could be considered 'ram air'
Old Aug 29, 2009 | 06:37 PM
I think wiki has the definition covered, but basically if you increase the air pressure or reduce the vacuum in the manifold its a ram air.
ScubaStevesVtec
Jun 30, 2006 06:51 PM
ef9wpb
Aug 26, 2004 10:48 AM
animated_life
Dec 27, 2003 12:03 PM
Neukin
Jul 23, 2003 08:47 PM
Custom Rex
Jan 12, 2003 06:12 PM
