Fresh Rebuilt Motor Runs like Crap!
Old Aug 21, 2009 | 04:14 AM
GEN2 LS's Avatar
Loved
Default Fresh Rebuilt Motor Runs like Crap!
So just put a new shortblock in my car it's a fresh rebuilt motor (b16) and it's still idling like my last motor (rings were shot), injector number 2 doesn't seem to be firing or i'm starting to think my wiring harness that runs into my injector harness is screwed up somewhere. On my last motor cylinder number 2 had 30psi of compression, I am gonna do a compression test today to hopefully rule out "low compression". the car just runs very rough and sounds like a subie, I disconnected each injector clip one by one and the car shuts off if I disconnect injector 1,3,4. but if I disconnect injector 2 car stays running and nothing changes, I swapped out the number 2 injector and still no difference. I checked that cylinder for spark and it has spark, I put a few drops of oil in cylinder number 2 and the car still ran the same, so until I get a compression tester i'm guessing the compression is good. the only thing I didn't get checked when I did the rebuild was the head. do you think a bent valve could cause this? Even so I think it's more of a fuel problem than anything.
Old Aug 21, 2009 | 05:55 AM
Nick97hatch's Avatar
Default Re: Fresh Rebuilt Motor Runs like Crap!
Yes, a bent valve will make the motor run like crap. Get a compression tester and test. Check cam timing and then check ignition timing.
BTW: Why would you rebuild the bottom end and not the top? Sounds like a recipe for broken motor
Good luck.
Old Aug 21, 2009 | 02:25 PM
GEN2 LS's Avatar
Loved
Good luck.
got laid off from my job bout 2 weeks ago, and money is very tight hence why I didn't spend all my money on the car. compression test came out 190psi cylinder 1 100psi cylinder 2 190psi cylinder 3 190psi cylinder 4.
took the head back off and to the machine shop to get pressure tested, no valves are bent, but the guy said both exhaust valves on cylinder 2 were leaking a little bit, so I guess that is my problem.
Old Aug 21, 2009 | 06:09 PM
killerpenguin21's Avatar
are all your spark plug wires on correctly?
seen it many times/done it myself once...will idle like crap and be loud and poppy if the firing order is wrong.
Old Aug 22, 2009 | 07:33 AM
GEN2 LS's Avatar
Loved
firing order was correct.
Old Aug 22, 2009 | 01:19 PM
b19coupe's Avatar
That is your problem.
Old Aug 23, 2009 | 09:03 AM
GEN2 LS's Avatar
Loved
upon further inspection it was not the shortblock, rings and pistons and cylinder wall in number 2 was fine, took both the exhaust valves out of cylinder#2 on the head and found that half of the guide was missing so theres the problem folks!
kPRO dz
Sep 6, 2009 07:55 PM
SpoonEk253
Jul 10, 2007 05:54 PM
street dreams
Nov 21, 2004 05:12 PM
street dreams
Nov 21, 2004 02:44 PM
