Condenser Fan Question
Old Aug 20, 2009 | 07:04 PM
Jimster480's Avatar
Default Condenser Fan Question
Is there a place to add fan oil to the Condenser fan? Mine is spinning pretty slow these days, causing the AC to overheat in the daytime when im sitting still and making it turn off. Which leads to a VERY HOT car. I need to fix this ASAP as im starting school on monday and am going to have to drive at different times of the day for different classes in miami traffic.
Old Aug 20, 2009 | 07:43 PM
shawn_crx's Avatar
Default Re: Condenser Fan Question
This is the first time I heard about putting oil in the condenser fan..
Old Aug 20, 2009 | 07:51 PM
Jimster480's Avatar
ya well its not running very well. And I know most fans need some kind of oil so ya.
Old Aug 21, 2009 | 10:49 AM
Jimster480's Avatar
what happened? nobody knows this either?
Old Aug 21, 2009 | 12:09 PM
ISOL2K7's Avatar
New User
buy new fan or go to local junk yard
Old Aug 21, 2009 | 12:13 PM
dpetro1's Avatar
its an electrical fan, you dont add oil to it. if its spinning too slow then its not being powered properly or its failing. check the voltage with a multimeter, if thats good then replace the fan.
Old Aug 21, 2009 | 01:04 PM
Former User's Avatar
Old Aug 21, 2009 | 01:09 PM
Jimster480's Avatar
i guess im going to have to
And most electrical fans have oil in them. Because basically all fans have bearings. When the oil gets out or burned up then the bearings cause alot of friction making the fan spin slower. its happened many times with my computer fans next to my high performance high heat parts, cheaper bearing (sleeve) fans tend to fail. Where ball bearing and Hydro bearings or Maglev bearings stay alive. Most big fans are the equivalent to "sleeve" style bearings as long as its direct drive and not by a belt, etc.
technine
Mar 19, 2009 04:12 PM
eric416
Apr 14, 2006 12:16 PM
Coltmorris
Feb 4, 2006 02:41 PM
B18EG6
Aug 23, 2005 10:41 PM
