Finished putting my B18C5 back together...
Old Aug 25, 2002 | 11:23 PM
tonyxcom's Avatar
Default Finished putting my B18C5 back together...
Well, after I found out the guy I purchased my ITR motor from, unsucessfully ran a JRSC on the motor, I decided a complete rebuid was in order.
I initially was going to just change the pistons and rings, but that turned into all bearings, almost all seals in the bottom. The head got the new valve stem seals and a standard 3 angle valve job.
The block was honed and Spoon ITR pistons were used. Everything else is stock. This is going in my 96 hatch in a couple of weeks, in which I will decide if I am going to swap my gas tank as well for the stupid PTANK sensor.
I forgot to take pictures while putting it back together. It was apart for over two months and during that time I CLEANED EVERYTHING with simple green etc. When I say everything, that includes bolts! All that is left to do now is adjust the valves, but I need my buddies moroso wrench first.
But here are the pictures I remembered to take today. It is really clean
Old Aug 25, 2002 | 11:25 PM
turbo_ef9's Avatar
Default Re: Finished putting my B18C5 back together... (tonyxcom)
that thing is hella clean!!
Old Aug 25, 2002 | 11:40 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default Re: Finished putting my B18C5 back together... (VTEC CX)
Old Aug 25, 2002 | 11:43 PM
BlackDeuceCoupe's Avatar
HT White Ops
OCD, huh? LoL! Nice motor, bro...
Old Aug 25, 2002 | 11:45 PM
Looose_R's Avatar
Default Re: Finished putting my B18C5 back together... (GapxGuy)
can you shave in the reflection? looks real nice, gald to see you took the time to do it right !
deviant1's Avatar
i had a couple questions.
1. can you explain the seals for the block? never heard of the seals. (no flames please)
2. you replaced all the bearings for the block? what are the other ones besides the bearings for the main caps and rod caps? they go on the block itself too dont they?
3. did you have to do all the clearances and use plastigage and stuff? check crank end play?
sorry if these are lame questions, but im REALLY interested in building my own block. thanks!
Old Aug 25, 2002 | 11:53 PM
tonyxcom's Avatar
Default Re: Finished putting my B18C5 back together... (deviant1)
1 - the main seals are the ones on both ends of the crank, one in the oil pump, and one on the flywheel side cover. I also changed the o-rings on the water tube etc.
2- the only bearings are the mains, rods and thrust. All were replaced with new.
3 - I ordered the bearing colors that the block, crank, rods etc called for, then verified them with plastigauge. Checked the crank endplay with feeler gauges.
HTH
Old Aug 25, 2002 | 11:56 PM
marty's Avatar
wow.. clean enough to eat offa it nice radiator hoses.
Old Aug 26, 2002 | 12:03 AM
tonyxcom's Avatar
Default Re: Finished putting my B18C5 back together... (MugenEF7)
thanks, SAMCO owns!
Old Aug 26, 2002 | 12:04 AM
marty's Avatar
thanks, SAMCO owns!
lookin good tony... F puff daddy pdiddy or wahtever his *** is called these days.
Old Aug 26, 2002 | 12:06 AM
97hb's Avatar
WOW that motor is clean. You used simple green??? Keep us posted about the swap man.
Old Aug 26, 2002 | 12:08 AM
CTL's Avatar
CTL
damn thats so clean you could probably eat off it
Old Aug 26, 2002 | 12:09 AM
tonyxcom's Avatar
Default Re: Finished putting my B18C5 back together... (97hb)
Simple green with scotch brite pads on all the cast aluminum peices and valve cover. Then a wash with dish soap and water to clean the simple green residue off. Simple green sprayed onto a hand towel to clean the bolt heads and bolts. Nothing I hate more then greasy bolts!
Old Aug 26, 2002 | 12:11 AM
marty's Avatar
where does one purchase simple green?
Old Aug 26, 2002 | 12:12 AM
tonyxcom's Avatar
you can get it anywhere. Target, walmart, pepboys costco etc.
Old Aug 26, 2002 | 12:14 AM
marty's Avatar
cool beans.. uhm.. TTT until the work day starts on the east coast.. which is in about... 4 hours.
Old Aug 26, 2002 | 12:15 AM
IM ALL BOB's Avatar
go to sleep marty.. and damn clean if I had to say tony good work
you should start building motors TonyTECH =P
[Modified by IM ALL BOB, 1:16 AM 8/26/2002]
Old Aug 26, 2002 | 12:16 AM
marty's Avatar
Default Re: Finished putting my B18C5 back together... (IM ALL BOB)
dont worry bob.... honda tech'in at work helps me stay awake
Old Aug 26, 2002 | 12:24 AM
tonyxcom's Avatar
Let me make sure this sucker runs first
Old Aug 26, 2002 | 12:31 AM
threeclaws's Avatar
Gorgeous, it's awesome to see such care put into an engine. Go Vallejo, I have family there.
Old Aug 26, 2002 | 12:32 AM
ANB Clothing Co's Avatar
thats a beatiful motor
Old Aug 26, 2002 | 12:34 AM
hondalawnmower's Avatar
Default Re: Finished putting my B18C5 back together... (threeclaws)
and i thought, only In and Out workers say "cool beans"
Old Aug 26, 2002 | 03:42 AM
POLLO's Avatar
Default Re: Finished putting my B18C5 back together... (hatchthisback)
Werd !
Im the first East Coast viewer/replier !
Good Luck with your project.
Old Aug 26, 2002 | 04:49 AM
Suprdave's Avatar
Default Re: Finished putting my B18C5 back together... (Alberto)
Did you have the reciprocating assembly balanced with the pistons, etc.?
Looks like your gonna have a really nice, reliable motor on your hands...
Total Cost?
Suprdave
Old Aug 26, 2002 | 05:09 AM
broke1's Avatar
Default Re: Finished putting my B18C5 back together... (b20bastard)
lol
it sure like like it
