***Broken Prop Valve?***
Ok, I have a '91 Si with a B16 swap and I just relocated the prop valve and replaced the lines to steel braided lines. Now, I have been bleeding the brakes and I only get fluid out of the driver side rear and its a steady stream. So I move on to the next one and the pedal is really stiff and cant get and fluid out of the others! Im pretty sure I hooked the lines up right because I used a diagram. Should I assume the prop valve is broken? Any ffedback would help. Thanks in advance.
redcoats1976
Dec 3, 2016 07:54 AM
Xscort
Feb 15, 2009 11:59 AM
mingbling96
Dec 20, 2004 10:19 PM
BI8B
Sep 16, 2003 08:21 PM
