where do EVAP hose connected to ?
Old Aug 25, 2002 | 09:56 PM
Flamenco-T's Avatar
Default where do EVAP hose connected to ?
I installed my skunk 2 IM for my GS-R. and I forgot how the pcv hose connected to ?
I know from the Ol Breather chamber there 2 hoses, one goes back to the back of the blockand what about the other one ? the one that has the PCV valve.....?
I red the diagram from helm and basically the one with the valve goes back to the intake manifold, can I just tap a fitting to run the pcv valve back in the intake piping ?
I am just curious where in the GSR stock intake manifold does the PCV valve hook up to, I looked under the stock IM and there are nothing to hook it up to, just a nipple for the EVAP sensor hose..
TIA
Old Aug 25, 2002 | 10:01 PM
Mase's Avatar
Default Re: where do EVAP hose connected to ? (Flamenco-NA)
i had to *** rig a way to use the evap sensor with my skunk2 im, lemme see if i can find a pic
Old Aug 25, 2002 | 10:07 PM
Mase's Avatar
Default Re: where do EVAP hose connected to ? (CDooMe2)
here this is hard to see, but this is how i had it, i dont have my evap sensor hooked up anymore (since i changed over to obd1 and hondata) so i cant take anymore pics.
Old Aug 25, 2002 | 10:08 PM
Flamenco-T's Avatar
I just need it to go to any vacuum hose back to IM right ?
Old Aug 25, 2002 | 10:11 PM
Mase's Avatar
stan you will be running obd1, right? i say screw the evap sensor
Old Aug 26, 2002 | 05:51 AM
stick's Avatar
with my PCV u just extent the hose and it goes back to the stock location which is under the manifold.
i still have my evap canister in place.
whats u email stan and i will email a few pics of it to you.
ch00dlz
Jan 23, 2006 05:16 AM
houstondigital
Aug 29, 2005 11:48 AM
citanest
Jan 14, 2002 10:26 PM
