Climate control relocation
Old Aug 19, 2009 | 07:47 PM
Chorrillos99's Avatar
Default Climate control relocation
I've tried looking for threads on this subject, but have not been able to find anything recent on this subject. Will like to install the climate controls in a bottom audio console I got for my eg. Any advise will b greatly appreciated.
Old Aug 19, 2009 | 08:35 PM
jcdimvic's Avatar
Default Re: Climate control relocation
ive never seen it done, would like to see it though.
Old Aug 19, 2009 | 08:41 PM
thumper64's Avatar
If you extended the wiring, everything but the temperature control will move easily. The temp control is a cable and may need tweaking, idk, never tried moving it.
Old Aug 19, 2009 | 09:28 PM
Jackal6042's Avatar
X2
The temp control would be the hard part. In the location you are talking about it might have to be shortened a little. You could probably just cut the end off and rebend that circle at the end. But there is also the little clip on the dash that it attaches to. You'd have to relocate that most likely.
I'm removing all the heater **** in my EJ1, just haven't gotten my lower audio console yet to maybe try a relocation write-up before I junk the ****. But I think just rewire it, mount it in the audio console. Set the temp slider to hot and set the heater core to hot. See how much difference in length there is in the pull cable and modify it from there. But again you will likely need to relocate that clip that sort of helps guide the motion of the cable when sliding the slider.
Reids Del Sol
Nov 13, 2017 01:12 PM
chitownrida
Feb 22, 2007 12:38 PM
VeilSide_Mas
Jul 20, 2005 01:18 PM
Robster Craw
Jan 27, 2005 10:09 AM
Zoso1977
Nov 6, 2004 10:57 PM
