d16z6 high compression question
i'll be running around 11:1 compression, and i have a few questions
will i need a stronger starter or battery?
the reason i ask is because stock it's 9.1:1 and 11:1 is a significant gain and i'm wondering if my factory start has the chutzpa to turn it over
i was going to ask about the timing belt, but since i'm building it without cutting corners i figure i'll get a stonger one as well
you do not need anything. i have 11.5:1 and it works just fine
and i have the stock timing belt turning my skunk2 stage 3 cams with no problem
I had 12.5:1 in my old Z6 with Crower 3 cam. No issues. Cranked a bit slow but sure
No issues with stock Gates/Unitta belt. My current D15B2 has 12.6:1 and its a lot easier being non-VTEC and has Bisimoto level 2.2 cam.
TravisCadello
76
Apr 10, 2009 11:03 PM
Projekt_2nr
Jan 26, 2007 08:23 AM
