1991 Honda Civic Lx 1.5 Swap
Old Aug 19, 2009 | 04:58 PM
91 civicswap's Avatar
New User
Icon6 1991 Honda Civic Lx 1.5 Swap
Hello,
I am new to this whole thing. I would like to know what will bolt right in my car. I have a 1991 Civic LX 1.5 MT that has 130,000.00 Miles, I want to replace/swap the engine and have no idea as to where to start. What will bolt up to the old mounts, will i need a new ecu, will all exhaust bolts line up, will the drive shafts be in the right place, what transmission do i need, Basically i am after a swap from a 98 Hp 1.5ltr engine to something a little more powerful (Not FAST) that will get me around but still get up and go when needed.
any help is greatly appreciated.
Thanks,
Old Aug 19, 2009 | 05:11 PM
BiG ChOr!Zo's Avatar
Default Re: 1991 Honda Civic Lx 1.5 Swap
all the info you need...!!!
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/engine-info-1556981/
Old Aug 19, 2009 | 05:20 PM
New User
I am still a little confused. The 1.5 ltr is what engine? d15?
Thanks,
Old Aug 19, 2009 | 05:26 PM
90RENOsedan's Avatar
yep. 1.5 is a d15. you can look at the front of the block for the casting numbers. a 1.6 is a d16, or it can also be a b16. but b and d series are obvoiusly different.
Old Aug 19, 2009 | 05:30 PM
New User
ok, so is the difference between the d15 and d16 much? its seems as if the d16 is alot easier to come by than the d15
Old Aug 19, 2009 | 05:42 PM
its actually the other way around. only about 17% of all ef's came with a d16. the only real noticable difference between the d15 and d16 is the intake setup. the d15 usually comes with a dual point fuel injection system, whereas the d16 usually comes with a multi point fuel injection system.
Old Aug 19, 2009 | 05:53 PM
New User
Ok, so should i put a d15 back in or what is the more common swap?
Old Aug 19, 2009 | 06:11 PM
cheapest upgrade is to throw a zc sohc camshaft in that stock b2 head and go mpfi...!!!
Old Aug 19, 2009 | 06:17 PM
yeah, the zc is the cheapest quick upgrade, but the most common would be to convert the car to obd1 and convert it to multi point, and throw on a v-tec head.
Daniel Wirfs
Jun 17, 2019 06:08 PM
Beanbag0416
Nov 4, 2012 01:49 PM
90_civic_hb
Mar 18, 2006 07:00 AM
whiteknightef
Dec 6, 2005 06:32 PM
MRVINCE1
Oct 28, 2001 09:31 AM
