timing belt tensioner
yes. essentially. there is a cover for the hole where the bolt is on the plastic timing belt cover. just pop it out. if the cover is already off, just follow the timing belt until you see the tensioner bolt. make sure you follow a manual to tighten the timing belt properly and use a torque wrench. dont over torque that bolt.
trecool44
Feb 3, 2006 06:48 AM
trecool44
Feb 3, 2006 05:47 AM
