FS : OTC 6537 HUBTAMER ELITE
THIS IS FOR SALE ONLY....NO TRADES OR RENTALS
well i bought this tool set thinking i was going to put it into good use but things came up and need to sell...this is BRAND NEW NEVER USED
perfect to pull the front hubs out to either change/service your wheel bearing or even pull the hubs to change the studs
some additional information from the manufacturer:
-Taking a winner and making it better!
-Works on virtually all floating and trapped rotors found on domestic and import vehicles
-Fits behind the rotor. Pushes on the steering knuckle, not the rotor.
-Eliminates the need to remove the knuckle assembly. No need for a shop press or unnecessary front end alignments.
-New Ford adapter included for use on Taurus/Sable 1986-1995 and Contour/Mystique 1995-newer vehicles!
-Puller and adapter improved with addition of a beveled edge for easier use in tight fit applications.
-Impact wrench compatible.
-Updated case and application information.
Heres a great write up that i found here on honda-tech.
https://honda-tech.com/forums/acura-integra-6/wheel-bearing-replacement-using-hub-tamer-no-press-needed-1996133/
Willing to take a loss...this is BRAND NEW>>NEVER USED...
$260 Firm... I'm in LA area
bfitz
15
Aug 9, 2005 11:55 PM
GetawayInMoscow
Aug 5, 2005 02:15 AM
