Transmission & Drivetrain Gearboxes, Differentials, Clutches
Acura Integra Transmission Compatibility
Old Aug 19, 2009 | 03:21 PM
SupaHondaCRX's Avatar
Icon3 Acura Integra Transmission Compatibility
Ok so i have a b18a1 with a shot automatic transmission on it and i needed to know if the manual transmission from an 87 Acura Integra RS (i think it has a brown top) will fit onto my b18a1. and if not what transmission can i use?
thanks alot. the help is appreciated.
Old Aug 20, 2009 | 01:12 AM
stevenDAtegra's Avatar
Default Re: Acura Integra Transmission Compatibility
I'm not too sure if that will or not, I think it may have the same pattern as a D series but am not quite too sure and the splines for the clutch may be different.
Is this a daily driver and are you looking for a stock feel transmission or one for speed.
a1 and ys1 transmissions are some of the cable ls transmissions that will work. Then you could also get a b16 transmission that came on jdm crx's and ef's and it'd be quick but higher rpms while driving casually
Old Aug 24, 2009 | 06:59 AM
per4mance's Avatar
no the 87 will not work its a d seriers pattern. Its the same as a ZC
SupaHondaCRX
Nov 27, 2023 08:22 AM
TPRACING
May 4, 2010 07:08 PM
e30FTMFW
31
Dec 7, 2008 04:49 PM
VtecKiDD
23
Jan 26, 2004 12:46 PM
