usdm gsr engine harness on jdm b18c question
Old Aug 19, 2009 | 01:35 PM
Luke G.'s Avatar
Default usdm gsr engine harness on jdm b18c question
i know the gsr has the vtec pressure switch but the b18c does not, i ordered the gsr harness since it had the rhd harness on it. What do i do with the connector for the vtec pressure switch on the gsr harness?
Old Aug 19, 2009 | 01:46 PM
GSaura's Avatar
Default Re: usdm gsr engine harness on jdm b18c question
I used a USDM gsr harness on my jdm gsr motor. I made the jdm motor a usdm look-alike. I used a USDM vtec solenoid, intake manifold, crank pulley, and distributor.
Old Aug 19, 2009 | 01:59 PM
smokey.23's Avatar
i got the same problem
Old Aug 19, 2009 | 02:28 PM
raidacaipo's Avatar
correction: All usdm motors including the b18c1(usdm gsr) comes with a vtec pressure switch. All jdm motors including the b18c(jdm gsr or ITR) does not come with a vtec pressure switch. Why? because the usdm p72 ecu looks for one and the jdm p72 or jdm p73 doesnt look for one.
Why did you order a rhd engine harness??? its useless unless you want to use it as scrap parts.
I dont understand your situation. Do you have a usdm b18c1 or a jdm b18c? If your trying to use a right hand drive harness it wont work buddy..
If you have a jdm b18c motor with a usdm p72 ecu, then you will likely get a CEL for vtec pressure switch 22 because the jdm b18c motor doesnt have a pressure switch and the usdm p72 ecu is looking for one.
*There are 3 methods to fix this.
1. Heres a trick to bypass it.
http://www.phearable.net/tech/wiring/vtpsbypass.gif
2. You can simply use a jdm p72 ecu which doesnt look for a vtec pressure switch
3. Actually install a vtec pressure switch on your jdm vtec solenoid or replace the whole vtec unit for a usdm one that has a pressure switch on it already
Old Aug 19, 2009 | 02:40 PM
Luke G.'s Avatar
I did not buy a rhd harness i said the rhd one is on the engine because it came with it, I bought the complete swap from HMO. I ordered a USDM GSR wiring harness from rywire. My question is what do i do with the plug on the usdm harness for the vtec pressure switch? Just let it hang? cut it off?? I also have the jdm p72
Old Aug 19, 2009 | 03:00 PM
smokey.23's Avatar
thanks for clearing that up . so if u got the complete swap from HMO it should have the jdm ecu,i was wondering about the same thing, i just tucked mine in case i ever have to use it again
Old Aug 19, 2009 | 03:58 PM
raidacaipo's Avatar
okay I gotcha now.. just let it hang off or zip tie it somewhere for the future. Btw what car are you swapping your motor into?
Old Aug 19, 2009 | 06:37 PM
Luke G.'s Avatar
93 cx hatch.
Old Aug 19, 2009 | 10:26 PM
raidacaipo's Avatar
93 cx hatch.
so you bought a obd1 gsr engine harness correct? then everything should be smooth sailing.
Old Aug 20, 2009 | 10:38 AM
Luke G.'s Avatar
yes thats correct. Thanks.
Wol4
May 18, 2013 01:27 PM
EGricky
Aug 28, 2009 05:17 PM
newc1
Jan 16, 2009 10:41 PM
jrzy2nR
Apr 30, 2006 07:07 AM
